Front differential
Thomas Jackson Jr
I have an 02 Yukon Denali awd. My front diff took a shit and I ordered one but it’s a 4x4 with an actuator and not the AWD. Can I just swap the cone and everything in the cone from mine over to the new one?
S33k3r
Dallas, Texas
Your post is either unclear or doesn't make sense. As far as I know, a differential does not have an actuator. It is the Transfer case that would have the actuator. On an all wheel drive vehicle, you don't need the actuator, because it is always in four-wheel-high. If you are talking about transfer cases, I don't know enough to say, but I'd say a 4WD transfer case would not work out well for your AWD Yukon.
Larryjb
Does the OP mean transfer case instead of front diff?
new2yukon
Others have verified the actuator for the front diff but I would give you a heads up:
I realize yours is awd so this prob won't apply...but...if someone finds the system going into 4HI all by itself there are some culprits.
One culprit: My 2001 took a lot of investigating to learn that simply taping the harness connection on the front actuator prevents water from seeping in and randomly putting me in 4wd. Its a bad seal on my truck.
Just a note to anyone reading this.
T
Thomas Jackson Jr
yeah on these GM front diffs there is an actuator. My problem is that mine doesn’t have this because my truck is AWD but I messed up and ordered one that has it. I’ve done a bit of research and like the other people posted I should be good and have my truck rolling soon.
Super Moderator
Elev 5,280
Won't you need to engage that actuator permanently (full-time), then?
MTN_KDA
