Got my Diablew tune installed and heading out for a 120mi shakedown trip. My first long distance drive since I got her so wish me luck. Bringing my tools, extra fluids, belts, plugs and wires. Here goes nothin!!
No problem. You’ll be fine I’m sure but good luck to you.
992dr
Eastern N.C.
What Galante said. I think the factory ones may be metal, similar to what holds a CV joint boot in place, but I don't know for sure. It's secured to the Panhard bar. I used two huge zip-ties I got from an A/C repair man to secure mine.
Gotcha, thanks for the info. I have a few giant zip ties. I'll change out the ones I have for them.
The originals on mine wouldn’t work on my Spohn panhard bar so I used giant zip ties like the others mentioned.
That must be it. I must've cut the original ones off when I put my Spohn panhard bar on.
Thanks guys, appreciate the info
bfourman
Indiana
Tuned.
Back home safe n sound, when I picked it up I checked the transmission fluid on the spot and of course it was low, he took it back said they added 1.3qts so I figured it was good, checked it again when I got home aaaand it was still low, added another 1/2 qt, drove it down the street, checked it again and it took the other 1/2qt, I told them when I dropped it off that the pan took an extra 2qts and told him make sure you tell the tech, apparently that didn't get communicated but no harm no foul. looked up my records and that is 15k service on the transmission and transfer case been about a year and half, about 40k on the front diff and alignment, 3k on the oil. I am rough on it so it's treated well in return.
Had a hectic work week so I took it out for a drive last night to chill out and put some more shakedown miles on it. I've also been trying to burn off the tank of 93 to refill with E85. I only got it down to 1/4 tank so I filled it up from there. Fuel mileage dropped 4-5 MPG and I can't tell if there's any more power. What I can tell is that it was about $.81/gal cheaper and I found a solution for the catless exhaust smell. The exhaust smells almost like it did with cats.
Drok
Cold place in the north
Ive been trying out mileage of the gas tanks fulls for the different octanes myself. I can tell you that 93 has lasted me almost 3 days longer than with a tank of 87. I also towed a trailer with the 93. So maybe its worth the couple dollars more for the 93.
Yes i know its a very scientific method i have:cool:
Drok
So am i being too picky if i bring my truck back and have them straighten out the steering wheel (its crooked enough to notice) after they just did an alignment yesterday?
nope I wouldn't have even drove it way like that, hate it, the alignment guy should have known better.
wwiizz
