DurrtyBurB
AZ
Threw some 20’s off a 2019 Ram Laramie
Added some center caps off an Aveo
F48428C1-BFA9-49A2-B6F6-693AACC82558.jpeg View attachment 250767 A44F67EF-9507-4A27-B01D-964A41A1473D.jpeg
Didnt know Dodge had same bolt pattern as Chevy.
Yup. Since 2019 when they went to 6 lug.
Speaking of, y'all ever notice how similar a lot of the newer wheels look? The new GM, Ford and Nissan wheels all look like slightly tweaked versions of each other. Probably all sourcing from the same Chinese factory now. Ford kept their own lug pattern, RAM said "Eff it, we'll take GM's pattern". Nissan/Infiniti has had the GM pattern for years.
Merc1973
Maryland
Replaced plugs and wires at 277k yesterday. And ordered the Fram ball-less PCV valve, can't believe I never changed it since I've owned it. Old plugs were Autolite double platinum n gap was 0.08...a little worn. Plugs were not easy to get out. Air ratchet came in handy. New plugs installed with anti-seize and dielectric grease on boot ends.
I used:
Ac Delco single platinum gap to 0.04
Denso ignition wires
treehan77
TYF Fiend
Crestview, FL
I used:
What year is your Tahoe? I think mine must not have the pcv valve? I guess I’ll have to take off the valve cover to clean the orifice someday. Which spark plug model #?
Scottydoggs
NJ
theres a few cases where ford wheels fit gm cars too. mustang wheels fir w body cars. them bullets look damn nice on a grand prix or regal. the w bodys are 115.5 MM and the ford wheels are 114.7 iirc.
used cheaper stang wheels for my dr's. as they are wider then gm wheels. and i got em cheap.
Didn’t actually do anything other than get this update.
In all honesty I have to say you should get an OEM used harness and relay pack and return that one. There’s a member here (@ScottyBoy ) who gets them, cleans them up, re-looms them and sells them for about the same price as that one. All of the aftermarket ones have a tendency to melt when it gets real hot, like 100* days. Nelson, LS1 Fans, etc. My LS1 Fans harness melted when I was 150 miles from home on a 102* day and stranded me. I rebuilt it with 80 amp relay blocks and heavier wire and it melted again. My OEM one has been going for 2 summers with no problems. It’s a different design than the aftermarket ones. I wish I’d known before I went through all the crap I did. Just a heads up.
Sam Harris
Yup. Unfortunately, I’ve been unable to reach him after requesting one that he had for sale. [emoji53]
Drewphil
