Purchased a 2006 Yukon XL Denali today
If I get a 2004 console I just have to plug it and will work?
I'm really not sure. I read on here awhile ago that a guy was able to wire it into his obd to get his mpg to work. I'm not very familiar with the Denali, as I have a Tahoe. Sorry.
Bear77
South FL
Would be cool if you could wire in that module so it could display your mpg, and whatever it does.
I have the wiring for the plug if you need it. Would have to look thru my photos and then can post it. Didn’t check to see if it would work in the NBS from 03 up.
Should be plug n play if you’re going to do 04 to 04
I was able to get it to work on my OBS. The difference in the consoles is Thais doesn’t quite line up because the curves are somewhat different by the dash. IIRC, you would need to change the glovebox as well. Might have been 1 or 2 other pieces.
The guy that I knew who did his had a jump seat originally in his 04. He put the 02 Denali console in WITHOUT changing all the lower plastics. Imo, it actually didn't look bad, but I did forget to mention that in my original post. My apologies.
chadw
No ones mentioned that the reason all she hears is ads for sirius is.. the radio is on satellite (which is deactivated). Turn to the radio.
I was gonna get to that but she didn’t really want any help, just wanted to whine. I also wondered about the “baby deer” story. She didn’t say a thing about damage from hitting it, almost like this whole thing was a troll. Exactly one post still.
CNCMACHINIST
CNCMACHINIST
CNCMACHINIST
Yes I do I just want to get rid of the cd player
CNCMACHINIST
I also want to do leather and power seats but not sure if it's plug and play like the mirrors you helped me with.
CNCMACHINIST
What about the other device? I would like to get rid of that too.
That’s the secondary DIC that only Denali’s have. I just use mine to show the date. You probably have no use since I don’t think it will plug in to your harness. You’re on your own, I can only offer help with the CD player. I do know that’s not a standard size though so I doubt you’ll find a pocket to fit. Maybe ignore it or add a thin plate in front and PTM, IDK.
varminpoolteam
