Transmission in gear, Truck won’t move.
MEA403
I have a 2015 GMC Yukon XL (140k), I was driving home from work, maybe 4 miles from my building and my transmission starts slipping. I pulled over, checked my fluid level. Fluid level is good and clean, no leaks. I put the truck back in drive and press the gas and the engine just revs, in both drive and reverse. When I put it in gear, you can not feel the transmission engaging. It will go into neutral, but that’s it. I am puzzled what it could be, any ideas?
Big Mama
Virginia
Have you been under the truck to look for anything obvious? Any DIC lights? Since you mentioned slipping it sounds like something inside the transmission.
Something in the transmission obviously, get it checked at a transmission shop. The newer ones especially are hard to diagnose over the internet. It’s the most complicated item in your vehicle.
Miami-Dade
Moderator Supporting Member
Out of curiosity when was the last time you changed your Trans Fluid at the dealer?
Probably the pump, maybe the torque converter. Could be time for the solenoids to be rebuilt. Regardless, the transmission shop will tell you it's completely broken and you need everything replaced for $3500-$6500.
I mean, if you’re going to tear one down you might as well. The cost of the parts isn’t what kills you, it’s the labor to pull it, fix it, and reinstall it. I wouldn’t remove a trans without rebuilding it, it’s not worth it. If you can fix it without pulling it that’s different.
ivin74
05 NBS Nali
Htown, Texas
Have you ever changed the transmision oil? Do you have the 6spd or 8spd tranny?
The valve body solenoids might be dirty, especially if you have never changed the oil.
M
MEA403
I have a trans fluid flush roughly a year ago. At that time the dealer reported no issues with it.
M
MEA403
The transmission oil was changed a year ago maybe a little more. It’s a 6 spd (6L80 tranny).
M
MEA403
I have no clue at this point. One mechanic said he can pull it and break it down. Another is saying just swap it. I do know on a cold start it drives and goes in reverse, but when the transmission heats up it slips and ultimately stops functioning.
M
MEA403
M
MEA403
It was changed a year ago maybe 14/15 months. I have no clue at this point. One mechanic said he can pull it and break it down. Another is saying just swap it. I do know on a cold start it drives and goes in reverse, but when the transmission heats up it slips and ultimately stops functioning.
PG01
Up here to the right
Years ago I wanted the trans in my beater 89 dodge w250 plow truck rebuilt and 2 guys I called said they would not just take the trans and rebuild it.. they wanted the entire truck, they remove/rebuild/replace trans, to make sure the truck was running right and that there weren’t any other mechanical problems.... never have I come across that prior to and since then, they wanted more money to remove/replace... they said they couldn’t guarantee the rebuild if I did that labor. It actually annoyed me to point that to this day when I pass the one guys shop I still flip the building the bird....
Big Mama
Virginia
Do you have a local indie you trust? They’re worth their weight in gold. An honest trans guy won’t just yank it out at first or say you need a new one or a rebuild they’ll check everything they can access from the outside.
I looked in the shop manual afterwards and saw that it could be something more severe, like a cracked drum that is bleeding off the pressure which then causes it to not move. Proper diagnostic computer will steer them in the right direction if not tell them exactly what's wrong. Having a GM dealership replace the transmission comes with a 100K warranty, so consider that.
Bob Miske
Have you tried putting it in 4 wheel drive? The same thing happened to me. I pulled off the interstate and stopped at the light. Light turns green, I go nowhere. I was on a downhill slope so I could push it away from the intersection. I called for a tow truck. When the driver got there, he asked if 4 wheel drive works. I limped over to the dealer to get the vehicle checked. The transfer case went out. The service writer says its fairly common. They had one in stock, so 4 hours later, I was back on the road.
Tiredmechanic23
Very similar to when my torque converter quit on my 2016 tahoe. Suddenly it flared a couple times then just would not go after a stop sign. pulled pan and lots of metal. I went ahead and upgraded the transmission. If you can work on your own stuff any the trans in this body style is super easy to get out and go back in.
nglauer
I just bought a 2015 Tahoe LT that the transmission went out within 24hrs from buying. It had 132,000 miles on it. Shifted fine test driving, then it croaked the next morning. It's being replaced now.
Sent from my SM-N975U using Tapatalk
Drewphil
