new2yukon
I like my husky weatherbeaters almost 3 years old now they do not slide or move at all, they still have all the little stubs on the bottom, I tried the weathertech and they folded in on me and then I tried some other brand and they did the same thing tossed both in the garbage, I have the captains chairs in the back and I do have the wethertechs in back but those do not have any part to fold in like the front ones plus I got a decent deal for the rear ones
What do u mean "folded in"? Plastic lost form and got soft?
05Single
afraid of the dark
Bombsquad85
Northern VA
Did the following that took some time but needed to be done.
Replaced:
R&R gearbox with rebuilt.
Steering cooler
High pressure steering line
Idler arm
Idler bracket
Pitman arm
Inner tie rods
Outer tie rods
Serviced front brakes. Lubed pins. Fixed issue with pads not sliding correct in calipers.
Changed rear diff oil.
Changed frt diff oil.
These trucks take maintenance. And I still have more issues to fix or pay to fix....like pinion and axle seeping.
Sounds like a lot of work. Nice job
ya the outer high side edge looses it's form and bends/folds in, usually doesn't fold enough to cause a problem getting in/out or driving but just looks like shit with a big gap and deformation
eithere side will do it, these are just some random internet photos of some, the one I put a circle in isn't too bad yet but that upper part will start deforming also
i can confirm it happens I threw mine in the garbage about 2 months after buying them
View attachment 248857 View attachment 248858 View attachment 248859
Why in the hell do they make that part 4” high? Just reminds me why I hate rubber floor mats, glad I don’t have kids. Imo they all look tacky. I had the custom carpet ones made when I bought my carpet, and use Eagle Klaw hold downs. I have had to clean them a few times but they do the job, the carpet underneath still looks new. I work construction so I get them muddy at times, I just try my best to not track too much in. Every time I see Weatherbeater or Weathertech mats I cringe. Too much sacrifice in looks to be worth it to me.
rgosart
I must have gotten lucky! I bought mine used and I have had them for almost 6 months. The pictures I posted were from last weekend and they are holding their shape much better than yours did.
I bought a used set that looked almost new. I just threw them in the garage right now since the Hoe is down. I hope I have the same luck as you do.
rgosart
I added two wireless charging pads to the pocket in front of my console. Took the guts out of the pads and hot glued them to the bottom of the pocket. They are wired to a USB outlet. Only downside is the USB outlet is connected to my cigarette lighter circuit so it is constant hot (I don't know who decided that none of the outlets in these trucks would be key hot). If I notice it draining the battery I will probably wire in a relay. Sorry for the lack of pictures, but they are in this pocket. Charges even my work phone through a thick otterbox.
Codered5557
