Complete Lighting/LED List
haks310
haks310
Got LEDs?
SoCal
The rear passenger doors were really easy, fronts were a bit harder. If you take your time and don't rush it then you'll be golden.
haks310
haks310
Got LEDs?
SoCal
I'm running LED tail lights so no 3157 bulbs for me. But on the stock tail lights you will need a regular 3157 LED for the top socket, a 3157 SRCK LED for the middle socket.
Door switches are plug and play.
HOUSTON
Thanks for list. LEDs are the biggest in the lighting market now.I work for a wholesale company in Houston and we are selling tons of these to car clubs/shops/etc. Thanks once again. I just put the dual color turn signals in and looks nice. Check out the videos here. www.myspace.com/nefariousautocustoms and look under the videos area
Brandon X
Michigan
Are the door lights easy to install? I'm worried about breaking the plastic to get to them and don't wanna mess that up.
Also, I want to replace the blinker indicators, is that just a T1.5 twist lock LED? Thinking about making those white or red.
haks310
haks310
Got LEDs?
SoCal
Door lights are easy, just use a flat head screw driver to pop them off.
Indicators are T1.5. But whether you do white or red LEDs they will still be green. You can do it, but it will be a lot of work.
Brandon X
Michigan
Damn they'll still be green? That's disappointing. Thanks for the help im glad you told me that before I went and bought em.
haks310
haks310
Got LEDs?
SoCal
Yeah. All the bulbs in the dash are white. The reason the indicators are green, red, etc, is because there is a colored film (green, red, etc.) behind the gauges.
Billy_ocean04
Michigan
Wich led taillight housings do you have and were they expensive? I want to buy a set but I don't want the cheap stuff but I also don't want to spend 300 dollars on them either. I've seen some out there that run about that much and as cheap as 105 on eBay
haks310
haks310
Got LEDs?
SoCal
$155 shipped of ebay.
Can't tell you what seller, I do remember that the brand is "eagle eye".
I've ran them for about a month without problems. Fit was also really good, not OEM, but good for aftermarket.
Brandon X
Michigan
Just order 4 more red 194's. I got the 90 degree viewing angle, I hope that's ok. Also ordered some white overlay gauges for my cluster, HVAC & light controls. Interior LED's are now complete. :) Thanks for all the help and info haks.
Rucksak19
South Coast / MA
2007-2010 GMC Yukon / Yukon Denali
Bulb List / Cross Reference
Exterior:
Headlight = H13
Fog light = H16 & H13
Sidemarker amber = 194
Turn signal amber = 3157
Puddle lights mirror = 194
Lisence plate = 194
Brake / Tail = 7443
Reverse = 7440
Interior:
Dome light (44mm) = 6418
Vanity light (31 x 5mm) = 3021
All bulbs can be purchased online at
www.autolumination.com
haks310
haks310
Got LEDs?
SoCal
T10 is just a another name for 194s...194 is more common though.
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
I went ahead and bought the white WLEDS for my cluster and A/C controls and they actually look like a light purple/bluish hue to them. I thought they were packaged wrong but both the t1.5's and the WLEDS are the same color. Not that they look bad, just was expecting WHITE and not purple!! lol just a little FYI there guys!!
Billy_ocean04
Michigan
I got the blue ones. Haven't put them in yet though. I think I want white now. I don't want a really deep blue. But I'll try them out and see how I like them
roadrageror
ROADRAGEROR
alberta,canada
just found this thread again...really want to do an int LED swap..just ordered all my LEDs for my ext on 99denali. GREAT thread HAKS!
TheBigler
Mobile, Alabama
hey what color white did you use for these on the inside?
scottd
