New to me 08 Denali
camarolvr11
Maine
Hello all, just picked up this 08 yukon denali for $6500. Has 222k, mostly highway miles. Excellent carfax service history and trans was replaced at 150k.
Plans Right Away:
  • Replace all 4 tires - has a sidewall cut in one.
  • Replace front struts and sway bar Bushings - original units, rides like crap
  • Replace radiator and water pump - original as well, want to do before it leaks
Future Plans:
  • MBRP catback exhaust
  • Airaid MIT intake
  • New headunit
C
camarolvr11
Maine
Pictures attached
received_859673181178546.jpeg received_287042578984430.jpeg received_689928365090832.jpeg received_167184424687988.jpeg
wjburken
Eastern Iowa
Welcome to the forum from Iowa. Looks great.
Might look and see how your rear air compressor and shocks are looking as well. If you decide to replace those, Arnott is what I would suggest.
I would also look at new plugs and wires unless they have been done recently.
Yeah carpet was dirty, but I got it out pretty good with some cleaner. Plus it came with weather tech mats. No rips anywhere
Howdy neighbor!
Thanks!
I've got family in York and Penobscot.
C
camarolvr11
Maine
The rear struts were replaced with oem ac delco at around 170k i believe it was and the compressor self test happens at startup as well. So I think those are fine.
Unsure on the plugs/wires but it does idle really rough. I've read about broken motor mounts on these, but going to start by cleaning throttle body
wjburken
Eastern Iowa
Plugs and wires should be swapped every 95k to 100k but many people stretch that. My guess at 222k is you’re due. Might also clean/check your MAF sensor when you clean your throttle body. With it being an ‘08, you don’t have AFM/DOD which is nice.
intheburbs
SE MI
Replace all fluids. That's the first thing I do when I buy used.
Oh, and keep an eye on the front diff. Don't neglect it. It's STUPID expensive to replace. Ask me how I know....:(
C
camarolvr11
Maine
Previous owner was mechanic and replaced all fluids at 200k, has about 222k now. Maintenance history also shows all fluids were changed at the scheduled service times as well.
91RS
GA
Arnott is junk. You loose the auto/mag ride and I’ve seen plenty of the airbags wadded up because they came loose, the top hat loose and sliding free, and most recently I saw one where the top mount came off and the rest of the shock beat the crap out of the auxiliary heater pipes. Just buy the GM ones from Rock Auto if you need them.
wjburken
Eastern Iowa
Interesting. Hadn’t heard this about Arnott. I have been using Arnott AS2708’s on my vehicles for almost 10 years, starting with my ‘07, ‘08 and ‘09, with no trouble at all. I will be putting some on my ‘13 very soon. Yes You lose auto-ride if you go with the AS2700’s but the reman’d AS2708’s maintain autorude dampening.
petethepug
Michael
SoCal
Interesting. ..: Yes You lose auto-ride if you go with the AS2700’s but the reman’d AS2708’s maintain autorude dampening.
News to me too. He prolly meant the version that’s made to defeat z55 / z95. Arnott is invested in their own future by constantly evolving their product to far exceed oem. They pay with poor workmanship and engineering when lifetime warranty products fail.
When purchased directly from factory, they pay for postage too. Not disputing a bad experience by any means though, keep the facts coming.
91RS
GA
Not trying to derail this thread but I do have a picture of the one where the upper mount came apart.
Miami-Dade
Moderator Supporting Member
Nice find on your extremely well maintained 08 Denali! That is definitely hard to find!
Welcome from Miami Beach Dustin!
dubyagee01
Nice buy. I second the factory replacement parts for autoride or remove it all completely. Including replacing the rear springs with a non autoride set. Weak and failing autoride ruins the stability to almost an unsafe level while driving. Especially if the front alignment isn’t perfect.
CKendrick
