RST Black Trim
CMoore711
Clarifying that you have the short wheel base helps, it was unclear which wheelbase you have in your post#38.
There are different part numbers for each the short wheel base and the long wheel base, this is because the rear doors are different from each other. That being said the part #'s for the front doors are the same for each short and wheel base with only the part numbers for the rear doors changing depending on which wheelbase you have.
OEM RST Black Window Trim for Short Wheel-Base '15-'20 Tahoe, Yukon Escalade
Front Left Upper: 84502328
Front Left Lower: 84126965
Front Right Upper: 84502329
Front Right Lower: 84126966
Rear Left Upper: 84502330
Rear Left Lower: 84126983
Rear Left Vertical: 84160204
Rear Right Upper: 84502331
Rear Right Lower: 84126984
Rear Right Vertical: 84160205
For Long Wheel-Base '15-'20 Suburban, Yukon XL, Escalade ESV
change rear part numbers to the following:
*Same Front Part #'s as above.
*Different Rear Part #'s
Front Right Lower: 84126966​
Rear Left Upper: 84126996
Rear Left Lower: 84126981
Rear Left Vertical: 84160206
Rear Right Upper: 84126997
Rear Right Lower: 84126982
Rear Right Vertical: 84160207
I would still confirm these with whatever vendor/supplier you are working with before purchase.
Hope this helps.
Tiki
I noticed that it’s coming on non RST trim levels now... same part number?
Blanch44
Oswego New York
I didn't see the Lower molding piece on either door in black. Either Chrome or Paintable. Put my Rear Pieces on yesterday . Getting there !!!
mbp1979
North Little Rock
Now here's a question for everyone. I know we like to swap what we dont have like everyone has chrome wants black and vice versa. But has anyone sold there chrome trim? Mines in good condition just wondering what it was sold for and where did you sell it thanks.
mbp1979
North Little Rock
I didn't see the Lower molding piece on either door in black. Either Chrome or Paintable. Put my Rear Pieces on yesterday . Getting there !!!View attachment 246715
View media item 28283
Here's all the part numbers I just swapped all mine out and put a black rst grille on there. Hopefully this helps there's are all the part numbers for a tahoe.
Tiki
Anyone have the PN for the Black D pillar?
Brother Bluto
Hope this helps.
Question on this>
This part is no longer available. Is it the same part as 6996, and can be used on either side?
mbp1979
North Little Rock
Might get a answer if you were a little more specific. Left side, right side, tahoe, suburban since both models are being talked about in this post. Just saying not trying to be a smartass.
Brother Bluto
Question on this>
pootskoot
Do anyone have the part numbers for the black RST running board trim and the rear bumper black trim? I just placed the order on all of the parts for the window trim, mirrors and front painted grill but cant seem to find the parts I'm inquiring about. HUGE Thank you to the folks that listed all of the other parts!!!
a1parrothead
