2015 Suburban..Water pump removal
Dexmon
Hi I have a 2015 Suburban and I'm trying to replace the water pump but no matter how I try I can't remove it. I tried prying it out but it wouldn't even budge. Any suggestions on how I can remove it? Thanks for your help.
GMT800 2005 Tahoe Z71
Navy Supporting Member
If you are sure you have all bolts out and are prying on it, something is wrong. I would bet you have a bolt you have not removed. If you want to take a hammer, metal or rubber, and impact it. If you are replacing and have no core charge, no big deal.
D
Dexmon
There's six bolts on the water pump that attaches it to the manifold. I removed all 6 and it still isn't coming off. I don't want to use a hammer on it because I'm afraid I'll damage the manifold as well.
That thing is not bolted to a manifold. It is bolted to the front of the engine block and you are not going to break the engine block. There is a void on the passenger side of the engine block behind the water pump. Use a pry bar in there and pry the water pump off or use the hammer I suggested. Did you watch a you tube video?
D
Dexmon
It is not bolted on directly to the engine block. Look at the picture I inserted. What I circle in the picture is what I'm trying to remove
That whole assembly is the water pump and not just the place you have circled. This is the assembly: https://www.rockauto.com/en/moreinfo.php?pk=10622996&cc=3307626&jsn=2227&jsn=2227
and if you read the description it says 7 attaching bolts and you said there are 6 bolts. You still have a bolt in there to remove.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
D
Dexmon
OK bro I'll go check again and let you know. Thanks for your help and stay safe.
Kpwweb
There is a bolt hidden behind the pulley such that you have to rotate the pulley and line up a hole with the bolt. Did you get that bolt out.
There is also a bolt on the bottom that is hard to see—you have to feel it.
D
Dexmon
The 7 bolts is for the assembly in the pic and not for what you may be doing. Plus, yes, that design is the complete assembly with the manifold. But when you look at this:
https://www.rockauto.com/en/moreinfo.php?pk=8445196&cc=3307626&jsn=2225
it still says 7 mounting holes.
It's actually 6 holes my friend. I called a friend of mines who's a mechanic and he told I have to hit it with a hammer to knock it out. I guess it was seized up. I hit it three times and if came right off. Thank you for your help.
D
Dexmon
Hi my friend I got it out. I hear to hit it a few times with a hammer to knock it out. I guess it was seized up. The truck had 263,000 miles on it. Thank you you for your help and be safe now.
Yea, I can't see what you see so I was going off of what the attachment bolt count was at the link. Great that it came loose buy using my other recommendation though.
frontstmaui
Agreed... I have a couple of questions... 1) How bad was your water pump when you decided to change it?? If it was REALLY bad and the bearings/seals warped, it might have become lodged in there. Which means you are going to have to really go to town with it. I have foregone my core charge before with items and tapped/die'ed a bolt on parts to get leverage or fit a tool in there to remove things. 2) Is it the OG pump? Because some idiots will replace a pump and put WAY too much gasket seal on. Try getting a razor knife in there. I know it is tight. But even an inch or so can make a difference.
Bob LaFord
