Which water pump
BrainDead
gonna throw in a new water pump with the radiator for "gp" but can't tell the difference between the two.
1. ACDelco #252901
2. ACDelco #251713
They look the same to me, the 2nd one has mounting hardware and a thermostat. I already have a thermostat and the mounting bolts, but what else am I missing between the 2?
B
BrainDead
The more expensive one is original equipment.
The other is the AC Delco Professional grade. Not the super cheap line, but in the middle, quality-wise.
You would think the professional line would be top of the line
GMT800 2005 Tahoe Z71
Navy Supporting Member
I see this post got switched from the 2000-2006 section. Great. Naming it "professional grade" would seem better than OE but alas, it is not. Good quality but not the better of the two. Think of it this way, your oe one lasted a long time and to reorder the same would get you like results. Always do the new thermostyat and I also like to recommend a new reservoir cap at the same time. https://www.rockauto.com/en/moreinfo.php?pk=4646841&cc=1433259&jsn=3371
New belts as well?
Korbin_A
