GM should bring the pewter color back...
wildcatgoal
It's just a beautiful color that ages well and needs to be offered on every Chevrolet truck, at least.
Also, behold my Tahoe "flexing"... because I think I'm cool.
I enjoyed the steering wheel rattle driving the trails... that was awesome after replacing literally freakin' everything.
GMT800 2005 Tahoe Z71
Navy Supporting Member
When it was installed did you lube the new part at the contact/mount points?
drakon543
me and the wife both actually aren't fond of that color or any variation of a gold/brownish color. i also have a strong dislike for yellow on a vehicle.
Sarah_279
PA
Pewter is a great color. I have Pepperdust. (not the same but as close as I could find to a neutral color..) I don't care for white and I don't have the patience for black :)
W
wildcatgoal
It's lubed where it connects on both sides, albeit that really shouldn't be necessary, plus I attempted to pack additional lube into the articulating shaft area, but there already was some.
I went under the column again and see some kind of black and bare metal object and by feel I could determine it had a 4 wire connector going to it. That object is so loose it rattles like crazy. It was hard to determine but I think I could feel it rattle in the steering wheel when I reached a finger up there and shook it around. I'll have to figure out how to get that lower panel below the steering wheel off and check that.
I have no idea what this part is. Almost like however it mounts is now loose.
I also have that steering angle sensor and all that plastic rattles, so I'm going to remove that, albeit if I manually move that around I can't feel it in the steering wheel. But I already bypassed that nonesense at the steering pump so I'm going to pull that crap off. Has made ZERO difference on the highway.
I had a worker at a wrecking yard ask me if I had my truck painted that color a few weeks ago, he couldn’t believe (most of it) was original. The sun was shining on it and the metallic was looking awesome. Not bad for an 18 year old truck.
Z71Tahoe2004
Colorado
Nice. I dig those wheels. I've seen those (14-17 Silverado OEM, yes) on a couple of other 04 Z71s on YouTube and believe I'm going to have to get myself a set. And new tires, too, I guess, since those wheels are a size wider...
Looks good!
Z71Tahoe2004
Colorado
View attachment 244151 View attachment 244152
Have you checked the bearing cuff on steering shaft on the cabin side of the firewall? I had a steering shaft rattle for months that almost put me out of my mind - then finally found that the bearing was the problem. It's a circular plastic piece that sits just about due north of the pedals when you're looking up from down in the footwell.
tom3
Never was a fan of Buick Beige. I'd go for silver or white for a neutral color, or about anything else.
Who cares what you like? I mean, really, white? Give me a break. And Pewter Metallic is not even close to beige. Go away.
Mark, that is so true. The typed word never gets the point across as well as saying it to them. Party on Garth!
carterchapman
guy
LOL - “Buick beige” - It seems like all 2003-2006’s were Silver Birch metallic. Just proves there’s something in this world for everyone!!
Durobans
