Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
Sam Harris
another thing id like to ***** about... accell ceramic cut to length plug wires. maybe i got a bad batch or something but the premade side that goes on the sparkplug, i had 3 of them that pulled the piece out of the insulator i even greased the things too. they were on there for like 2 months if that.
happened before and summit immediately sent out another kit and i was supposed to send back the other ones but now i need the two full kits just to get a single set out of.
View attachment 243028 View attachment 243029 View attachment 243030 View attachment 243031
Damn that’s bs. I was able to use the 9070C for the gen 4 engines on my gen 3, but I suspect you actually need the cut your own length ones since you know wtf you’re doing. [emoji16][emoji106] how much length do you need? This is a 427, right? Are the coils relocated? That why you can’t use the pre-made ones?
randeez
randeez
south florida
yea i have the coils pretty much up under the hood hinges on each side 16-24" or so long
01FormulaTA
damn what a bummer! hopefully they warranty it...u gonna throw in a junkyard 5.3 in the meantime?
randeez
randeez
south florida
if i could find one for a couple hundred bux id love to...4.8 5.3 whatever. need gen4 for the 58x crank, other problem is all the intakes i have are for square ports so i'd need almost an entire drop out
got anything laying around :rolleyes:
01FormulaTA
man nothing at the moment...I sold my 5.3 a while back, I wish I would have kept it, it was super clean....right now im putting together a budget 6.2 w 317s and a L99 factory cam and I want to tune it for 87 octane, Im gonna pull this 6.0 but I will need to use the intake and would want more than $2k for it anyways, sometimes some good deals pop up on eBay
I'll finish my 5.3, sell it to @randeez, and you hook me up with that 6.0?
randeez
randeez
south florida
just as much time as i've ever had :(
prob working more now that office has set everyone up with remote access. so now i get to travel down and make sure the toilets can still flush in broward county all week. and in my free time do design work for south florida water management projects
randeez
randeez
south florida
waiting on engine to get done/returned...havent really bugged them much. i called a week ago or so said they got it safe and hadnt torn it apart yet.
kind of holding up on doing other things to see how much /\s going to cost me.
when i pulled the engine, the converter wanted to stay in the center pilot of the flex plate and drug the converter out of the transmission (unknown to me) and with a 4x4 you only have about 2 inches you can come forward before you need to raise engine up, so i did all that with the f'n converter still between engine/trans and cocked it all to hell probably put a lot of pressure on the trans pump. i may pull the trans and take it somewhere local to throw on a dyno just to make sure i didnt damage anything if i can find somewhere at this time.
with the stupid belt problems lately:
i went through everything and put a plan together to delete EVERYTHING, mount the alternator low with short belt, the bracket to work with truck balancer (and keep ac!) is only like $65/15 bux for a belt. this would eliminate the powersteering pump (see below)
meziere 55gpm remount mount water pump, 417 motorsports water manifold...bmw has an oem PWM controlled electric water pump about 50gpm iirc. this could be achieved a lot cheaper but would like to have very good quality pump, there are other pieces that can mount in place of the water manifold but with this i could keep the heaters in the loop, steam ports into the top, clean install, minimal amount of fittings to leak.
electric steering rack out of a hybrid, from what i hear powered with no input reference (speed input) they have a default assist which works fine. im not sure if the lower mounted alternator will work with the stock steering rack also these are kind of expensive used $400-700, $1500+ new may grab cheapest one i can find to see if it all works first
brakes - would either go back to vacuum booster OR volvo/ford have an electric power steering pump that does the same thing as above with no input reference it has a default pressure that works fine these can be had for about $100. these pumps are oem quality i've heard of people using them for power steering rack AND hydroboost brakes so no doubt they would be adequate. i may go this route first if the hydraulic rack will work with the lower alternator mount and see how it does. as little as this thing gets driven and usually only when nice out i might delete the ABS block/pump
Wow you really must love working on this thing! That seems like a lot to do. Good luck.
randeez
randeez
south florida
This thing's a lot bigger than I thought.
Volvo electric power steering(eps) unit. Seeing the size of this thing really no doubt it'll run steering rack and hydroboost. got all the correct fittings for the hydroboost unit to use an lines - will use combo of ptfe and stainless hard lines. eps uses a 16mm x 1.5 thread like the hydroboost but where the o-ring seats in it is pretty big, i had some neoprene orings from injectors that worked perfectly but i need to make sure they're ok with power steering fluid may need to get viton or epr
CrackerJack135
