No Power at OBD Port
DrummerDude70
Hello, all! Hope everyone is safe and healthy. Ok, so my '02 Tahoe a "service engine" light, so I took it in to be scanned. I was told there is no power at the OBD port and was told it could be a fuse or wiring issue. I'm thinking fuse, as no one has ever messed with any wiring in the truck. Anyone have any experience with this? TIA
andyd
Check to make sure your acc ports are working or a cigarette lighter. If not is is usually that fuse that powers the OBD.
D
DrummerDude70
I know the acc ports are operational. I drove it to lunch one day, and upon startup, the light came on. Don't know if that helps...
Jps0039
The two I have up front have not worked since I bought in 2010. Anyone know what fuse it is?
Jps0039
Just making sure there wasn’t something I had over looked or another I didn’t know of. Of course this has been checked before. Thanks for the response
iddqd
San Francisco, Comifornia, USSA
Just to make sure, you've got NBS rig (up to 2006), correct?
Cuz it's an NNBS truck on ur avatar
D
DrummerDude70
Ok. all! Sorry for the late response. It was, in fact, the 15A Cigar fuse. Replaced and rescanned. There was power at the port and the code came back as the heater circuit in the No. 1 O2 sensor in No. 1 bank. He erased the code. light went off. I'll replace the sensor soon, but has not affected drivability in any way. Thanks to all for the input! Cheers!
scottd
