Too fast for me! I don't like driving fast in the rain myself.
These goodyear eagle sport tires work really good, there not 60k mile tires but they sure do stick to the road I have to try really hard to even get a chirp out of them
if I can find somewhere to just order one without having to go out and measure my existing one that would be nice
R3cord303
Posse In Effect
Oregon Valley
I remember on my S10 there were 4 U joints a slip joint, and a carrier bearing I think its called. I’m curious what the dealieo is with the gmt900.
There is a place about 50 miles from me that makes them I would probably have to drive it over there so they can take some accurate measurements since mine is AWD I presume they would need to do the front as well
St. Louis
Driveshaft Flange maybe? Unless these trucks just use those U brackets that bolt over the U joint to connect it to the pinion flange?
I know the FMS aluminum driveshaft I have on my mustang has slip yoke/U joint/shaft/U joint/flange
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
89Suburban
Bull in the china shop
SE PA
M6-1.00, T25 Torx head
Appreciate you dawg. I knew you knew the size and the search in here was jacked today. Silicone wore off from the car wash scrubbers I guess so got some stainless screws and gasket washers installed. May not be the perfection expected around here but I’ll take function over a soaked leaking headliner.
CB225690-A164-4D8C-93E1-AA33AB43CB9B.jpeg D48C69F2-B210-424A-82C5-3D070AEF8D5D.jpeg 429C9AE4-FD99-4D19-B955-CCB1AD4BB3AC.jpeg AB8769B8-44FE-4871-A5AC-96B6D7A9ACDF.jpeg CC4FD113-603C-4EE0-8609-32170F12E4A1.jpeg
cfmistry
Got some moisture in the headlight. Those lights aftermarket? So much nicer with that grill.
Yup. The original ones had seen 13 years, were very pitted and had condensation inside. I replaced them with the $100 eBay special and guess what... condensation almost immediately. I have removed them and caulked them with silicone. TWICE. And the driver's one is still getting in water from somewhere... ugh...
telderjr05
