Foster Supercharger sound mod.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Been awhile guys, so I haven’t done anything with my truck for a bit and it was overdue for a mod. I came across a YouTuber who did a Supercharger sound mod. So I decided to give it a go and it basically makes the Sc whine more audible in the cab by running a tube from the intake into the cab. The tube has a film over the end so no air can be sucked into the intake. Anyways here’s a comparison video
So much better! Good to see you back @sumo.
St. Louis
Cool I guess if you like that sort of thing... Lol
Different type of supercharger (whistled all the time, not only when under throttle) I used to have a Vorteq S-trim on my Mustang. Those straight cut gears whistled so loud people could hear me coming blocks away. I eventually switched to a SQ trim with helical cut gears and is so much quieter, just a slight audible whistle. Stealthy.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
sumo
sumo
rhode island
2001 Yukon SLT
you should hear my supercharged S2000. Sounds like plane
St. Louis
:hitit:
What are the numbers on it?
UevqZP2xheoWFL5G7
2001 Yukon SLT
Peacock
Buffalo,NY
It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.........
Seriously if it makes you happy, just don't try and pass it off as a real one to impress people, reminds me of vibrating your lips off the old candy boxes with the clear cellophane to make motor sounds.
I'll stick with the real thing....lol
St. Louis
Here's a video taken in 2003 of my Mustang that's mostly stock except for the S-trim. It's much different now with much more mods. I have no good videos of it though.
Video from 2003.
1995 5.0 Mustang GT with exhaust, Cobra intake, and Vortech S-trim Supercharger at 14psi.
410hp/400tq letting off at 5000rpm
They said there was more in it and take it to 6000rpm, but I was reluctant with stock heads, block, and tranny...lol
sumo
sumo
rhode island
cool
& curious, how much stuff do you have hanging on your keychain?
:anitoof:
Haha well I also had my tool box remote hanging on a cabana clip so I don’t forget them for work. If I do, can’t open my box. That and the conjunction of the vibrating cracked dash lol
sumo
sumo
rhode island
but my vehicles are supercharged. The mod is only to make the sound more audible inside cab not outside.
Peacock
Buffalo,NY
Ok, I'll forgive you then..lol
I thought you were doing something like those fake turbo whistle things that the import kids put on.
Nice dyno numbers by the way, doubling is quite impressive, what other modifications were made besides the supercharger ? I would assume fuel pump, injectors, exhaust ???
St. Louis
14.7psi is double the atmospheric pressure, so running that much boost should double the unboosted output of the engine.
The rear wheel hp numbers on my mustang before the blower was 240hp and I think 290tq. At 14psi boost the hp was 410 but they ssid if I would've taken it up to 6000rpm instead of letting off at 5000rpm, it would've peaked at about 460-475hp.
2001 Yukon SLT
Peacock
Buffalo,NY
I was making 50 hp per psi of boost on that engine in the video, I was only able to get 3 lbs boost with my pulley/belt combo (4 pulleys and 2 belts) that I took with me, my belt wouldn't fit the next combo of pulleys unfortunately. I wanted to limit myself to 6 lbs with the 93 octane I was using, just about the limit with the old roots setup.
I should be more efficient with the new setup, now to just figure out how to plant it...lol
sumo
sumo
rhode island
1000cc injectors, 320lph fuel pump. Aem V2 EMS, headers, test pipe. Kept OEM exhaust. Haven’t found one I like personally I think this sounds perfect. Upgraded the clutch, changed the flywheel to the 1st gen years, 14.5lbs vs 22lbs, larger throttle body. Installed Big brake kit and SS lines
Peacock
Buffalo,NY
Which flywheel do you have now, the heavier one for more kinetic energy or the lighter for faster revving? Looks like you really went through everything to compliment each other, which is what's needed, it'll sure find the weak link in a hurry.
sumo
sumo
rhode island
I have a 04 which is considered AP2. These years redline 8000rpm. And the flywheel weighs 22lbs. Ap1 flywheels weight 14lbs. Before 04 ap1 S2 redlined at 9000
so I opted for faster reviving since the supercharger can make up for the difference in weight. Also when I tuned my redline was changed to 8800. So I have a screamer of a sports car.
albac
