ThwopKing
Lowering kit is on....but not finished yet.
I know guys that are boosted or running high HP like to go back to the 4 corner steam pipes because there’s supposedly heat buildup on #4 & #8 under duress. But I deleted the TB part of mine and am running the 2 corner one.I know they decided the rear ones weren't necessary and so they made the block-offs. But, I can't imagine them deleting the front ones.
That crossover through the TB is some BS. You know how they fixed it in the newer gens? They simply angled the TB a hair so any moisture that may be around the throttle blade won't collect on the blade where it could freeze.
Lol I was about to attempt the same thing. Then I found my airaid mit tube locally for $40 so I grabbed thatI did some cutting and patching of a cold air intake elbow I got at the junkyard. It won't win any beauty contests, but it sure beats the octopus that it will replace.View attachment 242024 View attachment 242023 View attachment 242025
ya that's what I am going to do with hers just run the hose from the radiator to the pipe and bypass the TBI know guys that are boosted or running high HP like to go back to the 4 corner steam pipes because there’s supposedly heat buildup on #4 & #8 under duress. But I deleted the TB part of mine and am running the 2 corner one.
usually that is the sway bar bushings, try greasing them I think what happens is the grease gets thin and then when water gets in water is a terrible lubricant so it makes it pop instead of moving smoothly.Water pump, thermostat and fan clutch in. I have heat now!
Now to figure out why I get a pop from the front left area when turning left only when it's damp or raining. Quiet as a mouse when not wet.
I though they only sell poly ones? Also, you might want to buy their greasable sway bar bushings since there’s no way to grease the OEM ones without taking them apart.Thanks. That is what I am going to try, just have to put my grease gun back together and lube the whole front end.. if that doesn't work, put new non poly end links in as I have the energy suspension ones.
This makes my truck club look weak as hell...haven't posted in a while. buddy is starting up a local truck club. he took some decent pics, thought id share....
View attachment 242521 View attachment 242522 View attachment 242523
No no no, it's those Fords that make the club look weak as hell. LolThis makes my truck club look weak as hell...
It IS weak as hell and the proof is right there in the foreground. F@#d.This makes my truck club look weak as hell...
It IS weak as hell and the proof is right there in the foreground. F@#d.Then the first GM has yellow headlights. Why did you make me look at that?
Don't worry. Those are the only fords in the group and there are over 30 people in the group.... F***.... For **** sake man.
I'll get pics with the nicer trucks soon, the actually good onesIt IS weak as hell and the proof is right there in the foreground. F@#d.Then the first GM has yellow headlights. Why did you make me look at that?
