What electrical functions did that generation have for 2nd row seats?Yeah. You’ll have to do some wiring if you want the power functions to work since GM changed the electrical system in 03
Only thing I've ever heard for 2nd rows is just heated seats on Denali's.What electrical functions did that generation have for 2nd row seats?
Well I might just swap the cloth over and not use the frames since the harness may be different. Just as long as the rear bolt in that would be great, the leather in the hoe right now is garbage now.Yeah. You’ll have to do some wiring if you want the power functions to work since GM changed the electrical system in 03
Foam and cloth. Hopefully frames are the same--should be.meant the front seats but the foam pattern changed in 03 too. You’re better off swapping the whole seat
Well nvm, they sold the seats. Dammitmeant the front seats but the foam pattern changed in 03 too. You’re better off swapping the whole seat
I'm in the middle of replacing my power steering pressure and return hoses I noticed some oil around the pan in the front.
You guys think that this is just weeping and maybe pan bolts weren't tght or potentially oil pump? Or something else?
Picture was taken from ground looking up at front of engine.
Not truck related, but I did wire up some 220v in the garage for the welder
