Scratching my head after transfer case fluid change...
wjburken
Eastern Iowa
Sorry for not being PC lol....hopefully my buddy working at the dealership gave me the right shit, everything is working well....
BG Ultra-Guard LS
SAE 75w-140
API GL-5
What is this for? Rear differential? I thought our generation called for 75W-90 Synthetic, not 75W-140, in the rear and 80W-90 in the front.
jmm121783
Searching for the next sunset...
Detroit
ya i was given the wrong shit by my buddy, he is giving me the BG Syncroshift II tonight....my apologies for any confusion
jmm121783
Detroit
I appreciate your response. In my past experience I always cracked both plugs loose, took the drain plug out first, so it would not erupt. Then by the time I opened the fill plug, all was under semi-control. This is a new one to me.
Could you guys link me to this pump thing you used to load up the Tcase? My method sucked and I definitely want to try your way!
Thanks!
89Suburban
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I use the same thing. Works good. You can also use one of the pointed bottle caps cut so a long piece of tube passes through it and reaches the bottom of a quart bottle. It needs to be tight so it seals. All you have to do is squeeze it in.
EricBeau
