Power steering has left the building
SpThomass
So I sound dumb I know, but I’m leaking power steering fluid, and im going to fix it in the near future, but the only part that I find confusing is the hydro boost.
Do I have it? How do I know if I have it?
Where is it? Any links for more information on it?
thanks
Big Mama
Virginia
Welcome from Virginia Thomas. Nice rig. Others will chime in with specific questions for you.
wjburken
Eastern Iowa
thanks
It might make it easier to answer your question if you share a little info like the year of your vehicle.
Give us some truck-related details, Thomass, and what you have done so far to diagnose your issue, and folks here will share their suggestions and perspectives.
SpThomass
SpThomass
My bad didn’t even think about that, it’s a 2006 GMC Yukon denali XL lol
SpThomass
SpThomass
The PS reservoir drains pretty fast, I’ve narrowed it down to the high pressure line, return line, and the cooler/ cooler line, but I’m not too sure. And to add to that, I’m not sure if I have hydro boost or not, let alone where it is if I do.
Multnomah Falls
Military
adventurenali92
Big Bear Lake, ca
My 2006 has hydro boost, so I’m assuming yours does as well. It’s mounted on the drivers side of the engine bay, in between the underwood fuse panel and the firewall right below the drivers side windshield area.
SnowDrifter
Washington. The desert side not the Starbucks side
Post a picture of your brake fluid reservoir
Though, with respect, if you can't track if there's a hydraulic line going to your brake booster / identify a brake booster, I think this one might be best left to the professionals. Having a power steering failure from a learning moment on a repair is no good!
rockola1971
Indiana (formerly IL)
The hydraboost is located directly behind the master cylinder where traditionally a ROUND vacuum brake booster would be. There will be a power steering line coming off the power steering pump going to the hydraboost. Thats because it uses power steering fluid under pressure to actuate and give you leverage to operate the master cylinder while braking. I have a 05 Yukon Denali and I can tell you that most likely the hydraboost is your leaker. Its very common. Look where the master cylinder bolts to the hydraboost. Is it wet on the underside of them? If yes then its because the hydraboost piston seal is leaking.
Ill let Eric walk you through it....because Eric rocks!
Ihaveatahoetoo
