You've done your research on this so I'm asking you. Can you leave the stock cam and change over to LS-7 lifters to do DOD delete or do you have to change to a non DOD cam?
It'll "run", but those four AFM cylinders will have lower compression and the imbalanced firing will throw misfire codes. You can tune it to help it and maybe avoid the codes, but the engine will still feel stupid.
For mine, I bought a Gen3 L33 cam since it has identical specs as the stock Gen4 AFM cam, but with all lobes matching. For that cam I got a 3-bolt cam sprocket with the Gen4 trigger setup, it's a GM part. There are center bolt Gen4 non-AFM cams but the specs aren't quite the same. Close enough to run without a custom tune, though.
Since you brought it up, my L33 cam may be up for grabs. A buddy has a TSP Stage2 low lift truck cam he's offering to me for next to nothing. I wanted to avoid custom tuning to keep costs to a minimum, but I'm having the heads worked over so I'll need a tune anyway. Since I'm already getting a tune, the cam would be "free/cheap" power.
pwtr02ss
Tennessee
For mine, I bought a Gen3 L33 cam since it has identical specs as the stock Gen4 AFM cam, but with all lobes matching. For that cam I got a 3-bolt cam sprocket with the Gen4 trigger setup, it's a GM part. There center bolt Gen4 non-AFM cams but the specs aren't quite the same. Close enough to run without a custom tune, though.
Thats what I Thought. Thank you for the info. I'll probably just hope to get another 50-100k out of a lifter swap. lol
R3cord303
Posse In Effect
Oregon Valley
low lift stg 2 is 10/10. I may have to get redynoed and we’ll compare numbers
lol, no it was pieces of rebar or something similar, I'm pretty sure they are pieces of rebar for doing driveways since they are about 18"
Yikes, we've had people impaled with rebar down here; falling out of an uncovered truck and going through a windshield. Count your blessings. No tire damage?
Lifter swap as in swapping in regular lifters or replacing AFM lifters? There's an updated design of AFM lifter and installing those would make it a plug-and-play deal and you could keep your current cam, valley cover, etc. No custom tuning would be necessary. Having new lifters and keeping the system turned off may very well give you another 100K+ miles. I'd enable AFM to cycle the lifters for a while right after installing them, though. If you wanna do it on the cheap, this would just cost you the lifters, trays and gaskets.
I'm trying to not get my hopes up a whole lot since there are some extenuating circumstances beyond our controls, but the deal's looking very possible. I really doubt I'll have dyno figures, but I live less than 5 miles from a 1/4 mile strip so I can calculate from that.
Now I'm wishing I had gotten some baseline runs at the track.
...Hmmm. I'm 8 miles shy of 200K. It'd be cool to hit 200K miles at WOT on the big end of the strip!
yes, 2 pieces impaled the truck and the 3rd impaled the tire then spun and ripped the splash guard almost in half, I posted pictures yesterday. the tire shop was able to fix the Tire with a patch
pwtr02ss
Tennessee
Yes, that's the plan. Just spend the extra money on AFM lifters and save the labor. It had the "updated" lifters installed at around 30k miles. They have lasted well. I'm at 198k, maybe close to 199k.
Yeah Chris! Get some runs in this week to baseline the truck!
I think we'll be up there towards the end of May, maybe we can get our trucks together at the track for some runs and photos?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I generally drive using the other 99.86% of the windshield that the wipers cover. That small area on the far end of the passenger side doesn't make a damn to me.
Also because of the edge lift, you wind up getting this dirt/dust smudge mark on the outer edge of that wiper path up the windshield instead of a clean line and looks like chit. SO there... :p
Preparing for a new air management system on the Silverado.
41FAA49D-D938-4A48-B285-1543FBDB0718.jpeg EBD0D31A-1EE9-40F8-B850-ECA5158B50BC.jpeg 15AB1B17-B134-45BD-BAA4-427250DB9AFF.jpeg
If y'all make it up this way, then come on with it! What's funny is that sometime towards the end of May, we may be headed to Tampa! lol
80MPH + rain seems to wash that off just fine. Coincidentally, it just so happens that during a rain is actually when I'm running my wipers! How convenient!
Paint Correction today! My girls used a Dupli-Color pen to clean out some rock chips and filled them in, along with a couple of scratches from the woods and mailboxes striking the truck. Also had a little patch of clear coming off the front bumper, so we wet-sanded that with 800 grit sandpaper and then taped it off and put 3 coats of Dupli-Color clear on top of that. In two days we'll wet-sand that area and maybe some of the scratches with 2000 grit sandpaper.
I was supposed to be in Tampa today, a relative had surgery at the Moffitt Cancer Center. I'll keep ya posted on when plans get finalized to head up your way.
HiHoeSilver
Away!
Chicago
Take any pics of the spots?
Escalade2007
