07-14 Yukon Headlights
Glisella
NY, Westchester/Putnam border.
First time I'm seeing these. I don't care that they're cheap projector housings and not HID, I'm liking the look. They have in clear and black.
https://www.ebay.com/itm/133223009909
https://www.ebay.com/itm/401941306500
Would love to see what they look like on the truck.
Screenshot_20200223-071551.png Screenshot_20200223-071542.png Screenshot_20200223-071536.png
St. Louis
I like the looks of those. Wonder which would look better on my Carbon Flash Metallic colored Denali? I'm thinking the smoked?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Glisella
Glisella
2001 Yukon SLT
I'd say so, I like those better but on my white I don't like the dark headlights unless you have black rims, black grille, and no chrome on the truck. I still have all the chrome Denali stuff.
St. Louis
I think I'm going to order a smoked set.
2001 Yukon SLT
Geoffsfas10
St. Louis
The biggest issue with those is the porjectors suck, you will have the same amount of light as stock, and you run the chance of getting a set where the projectors arent lined up, so your light output ends up looking like this....
this is a similar U-bar styled tahoe headlight
St. Louis
I'm fine with thw brightness of my stock housings using Silverstar Ultra bulbs, but the Yukon uses one bulb (H13) for high/low beams and the low beam is also the DRL. I'd like the DRL to be a seperate light, which these are the LED. They also have seperate low beam (H7) and high beam (H1) bulbs.
2001 Yukon SLT
Glisella
Glisella
2001 Yukon SLT
If you get these please send a pic and let me know. I am on the fence and like you I'm okay with the stock output maybe I've just learned to live with it. As long as the light output isn't any worse with these I would get them simply for the style that they have, and I think having these DRL LEDs on along with LED fog lights would be a really good look in daytime.
BG1988
that beam pattern is for right hand driving it's correct
Geoffsfas10
St. Louis
thats about the only thing correct with them...there's glare everywhere and the drivers side is rotated clockwise horribly, the hot spots are in the wrong spots and that looks nothing like what a real projector can do
St. Louis
My lights were delivered today. Probably won't get them installed until this weekend though. I'll get night pics of both my stock and new lights shining on my garage door before/after install for a comparison.
Lights look to be decent quality and seem to be sealed well all the way around. The parking light has this little cup/diffuser over it that doesn't sit flush inside the lense housing, but both lights are like this so it appears to be made like that on purpose.
2001 Yukon SLT
wjburken
Eastern Iowa
2001 Yukon SLT
I like the look. Can’t wait to see pictures with them installed.
:popcorn:
petethepug
Michael
SoCal
Finally, a decent choice for the NNBS Yukon’s. The Coleeco era led’s in aftermarket headlamps came and went really fast.
They seem like a good candidate to experiment w/ led or hid drop ins.
Hmmm. Seller shows local address. May pick up a set tomorrow. He just pinged back. No local p/u. Bummer. Just pulled the trigger on the same lights in the murdered out black because I'm cheap and they're $50 less than the chromed version.
St. Louis
I installed these today. I went with removing the entire bumper, just made it easier. I turned on/tested them before re-installing the bumper, and found one of the parking light bulbs was burnt out. I had to run by the parts store and pick up a 194 amber bulb. I'll get beam pattern on my garage door pics tonight to compare with the stock lights.
I still may need to adjust them
2001 Yukon SLT
Glisella
Glisella
2001 Yukon SLT
They look awesome!
St. Louis
Update....
Those pics were with the car off and just turning the parking/headlight knob manually. When driving, the LED U bar isn't lit as the daytime running lights, but the low beam/projector is. The LED U bar only comes on when parking or headlights come on.
The add says the LED U bar is the Daytime running light bar. I may contact the seller and ask.
2001 Yukon SLT
St. Louis
Also, I need to find another one of these pieces that mounts in front of the wheel well and holds the top edge of the bumper cover on. It's supposed to have a threaded screw nut in the area that's broken, which holds the top wheel well liner screw. This is my drivers side, and the screw wasn't attached to anything. I just used a push-in christmas tree type fastener for it for the time being.
2001 Yukon SLT
2001 Yukon SLT
Nice!
petethepug
Michael
SoCal
Thank you sooo much for the pics Tom. Mine just arrived the moment you posted this. I was wrong, another seller has them in chrome for same price as blacked out ($299.99). Glad I pulled the trigger on getting these. Potentially, stuff getting imported for Asia may really slow down if the Tecate virus keeps up. The blacked out version from this seller are sold out. Some of the chrome are still avail.
https://www.ebay.com/itm/LED-Bar-Fo...847485?hash=item3fd4b9363d:g:XJIAAOSwcrVeO-al
Got a set of H7 PIAA 5000K bulbs off Amazon for $43 too. It's no fun getting to the back of those lights to swap them out if you get a bad bulb.
St. Louis
Here's a evening comparison on my garage door from 20 feet away. My OEM housings have Sylvania Silverstar Ultra H13 high/low beam bulbs in it. The new housings came with standard bulbs and uses a H7 low beam. I should've put some Silverstars in there before installing them.
I also sent the seller an email asking about the LED bar not coming on with DRL, only when parking lights come on.
I really can't see only the LED coming on for DRL without the low beams, because no matter what, the vehicle turns on the low beams for DRL.
On the Yukons, there are only 3 bulbs and 2 wire plugs. The H13 low/high beams with its own plug, and a 5702 turn signal and 194 parking/side marker with their own plug.
Looking at the back of the new housings, the LED wires tap into the plug/wires going to the turn signal/parking bulbs and not the low/high beam bulbs. I could probably rewire the LEDs to the headlight plug wires so that the LED bar and the low beam projector come on as the DRL, but I can't see how just the LED bar can activated as the DRL without the low beam headlight.
2001 Yukon SLT
Rooster2000
