Parking Brake control module
Multnomah Falls
Military
All good thoughts. That lip is likely causing the misadjustment at the shoes. Cable stretch too much, while does happen sometimes, is highly unlikely.
Yes, do the pads and shoes while in there and clean lube it all up. If you are going that far you could buy 2 rotors and get a new drum surface and skip the dremel tool work.
L
Larryjb
I may have to get new rotors. If I can hold off, that money can go towards gas money. The equivalent US$/gal in Vancouver BC is $4.30/gal.
Multnomah Falls
Military
If you put new pads, should be quality AC Delco ceramic IMO but your call, then the old rotors should be resurfaced providing they are thick enough and then they can machine that lip off the drum section of them. If not then get the new rotors and no machining is needed. If you put new shoes on, then while you are installing them or doing other work before you slide the drum over them, put masking tape on them to keep them clean on the surface before you are ready to slide the drums on. You should also use clean shop towels or other cloth towels and spray brake clean on the drum and rotor surfaces and wipe clean because there will be metal grit there that can embed in the pads and shoes and cause noises. If you have the rotors and drums machined and reuse them, this cleaning step is especially important. When you put the shoes on clean the backing plate surface off with a wire brush or circular disc on a power tool and completely clean and lube spots where the back/edge of the shoes make contact at the backing plate. Same with the pad mount areas. Wire brush and clean and apply high heat lube jsu at the contact and sliding spots. Get new pad hardware as well. Withe the shoes, make sure the adjuster wheel is unthreaded and threads cleaned and lubed as well.
I am a firm believer that a great quality brake job of any sort is a lot of prep and "cleanliness is next to godliness".
L
Larryjb
Maybe the Tahoe's are different, but I learned from my Grand Marquis to not bother with resurfacing rotors. Even though they were still within the specified thickness, they warped within months. I found that, as long as the rotors were within the specified thickness and there were no pre-existing issues with them, it was best to leave them alone and replace pads only. I'd give them a good clean with BrakeKleen, then reinstall. Specifically on my Mercury, I found that I had to replace the calipers with pads though, otherwise within months one of the calipers would seize.
A friend got me Raybestos ceramic pads once. They worked okay, but I had to apply the brake pedal more firmly to get the same stopping power. Once warm, they performed only as well as the semimetalics I had used previously. Maybe they've improved the composition of ceramic pads now, but I'm not eager to try semi-metallics again. I read varying stories about ceramics and towing. The biggest advantage to ceramics seems to remain lower noise and longer pad life. Some sites claim rotor life is improved with ceramics, other sites say the opposite. Some sites say ceramics are good for towing, other say the opposite. I'm sure it depends on the composition of the ceramics, so I'm sure that's why Ron recommended the ACDelco ceramics.
I used to use the anti-squeal compound on the backs of the pads. I stopped using it and used the recommended brake grease or high temperature grease instead. I found that I got better brake feel without the anti-squeal compound. They sometimes make more noise, but the feel is generally better.
Multnomah Falls
Military
The reason you apply more pressure is that you have a new pad surface and an old rotor surface trying to mate. Rotors are less and less thick now so weight is saved and adds more MPG for the manufacturer. They save weight anywhere they can. Using the old rotor surface is NEVER recommended. You are going to do what you feel good with. I get it.
You damn Canucks are set in your ways. I get it but that is flawed thinking. New quality rotors are better than machining them, especially with the cost of machining them compared to new cost. New pads, best is ceramic, and new rotor surface is best to burnish them and have a great pedal. I know that your thoughts about ceramic pads is because of your use of old rotor surface.
Plus, semi metallic were a much worse choice at the time and that is why ceramic was developed. Give new tech a chance. Hell, at 67, I am old but I learn new tricks everyday.
L
Larryjb
When I installed those ceramics, I did replace the rotors that time with ACDelco Professional rotors. That experience was on my 99 Lesabre.
On my Grand Marquis, I never noticed any difference in pedal effort when I did pads and calipers alone versus pads, calipers, and rotors.
L
Larryjb
Speaking of us damn Canucks being set in our ways...
I used to always have rotors and drums machined before the 92 Grand Marquis. Then when I had my first set of Marquis rotors machine and got run-out a few months later, that's when I learned to inspect the rotor, clean it up, and re-install if no previous run-out was present. So, I started reusing rotors because I was not stuck in my ways! ;) As long as the rotor surface is not badly grooved, it made little difference to the pedal feel whether I installed a new rotor or kept the old one. I would check the thickness and if it was approaching the minimum thickness I'd replace it. With semi-metallics I could get 2-3 pad changes on one rotor. The ceramic pads ate up the new rotors I had on the Buick.
Now, as for the Canucks themselves, yeah, they are stuck in their ways. They always seem to find a good goalie and rely on the goalie to win games. It got us to the play-offs a few times, but doesn't win playoffs.
Multnomah Falls
Military
LOL. I guarantee you that each used or older rotor has runout. You may not see it or feel it but it is there. Friction builds heat and that is what stops you and that heat transfers in to the rotor surface and over time it will warp a little. The thinner the rotor the easier and more it will warp. You are always going to do what you feel comfortable with. If you reuse the rotors without machining or replacement, then keep on keeping on. I have my ways and you have yours and neither is wrong, in my book.
L
Larryjb
Back to the parking brake again...
My parking brake has frozen a few times up here in the winter. While is is generally mild in my region (no we don't live in igloos), we get spells of winter air just below 32F. So, I felt it would be a good time to change the rubber grommets in the backing plates. Well, I discovered that the only way to change those rubber grommets is to remove the 4 bolts that secure the backing plate, pull back the caliper mounting bracket, then you can replace the grommet. I'll get some picture in the next day or two, but I've never seen any description of how to replace these grommets. Now I know.
Multnomah Falls
Military
Frozen park brake is usually because of age and crud in the outer cable casings or a kink or punch. Or hardware sticking.
Trickystick19
