HOW TO: Removing Rear Window Pillar Vents
YNOT
For anyone that wants to paint the stock vents, or replace them with Escalade or smooth ones. Here is how they come off.
On the top left there is a 7mm bolt and the bottom left is a metal tab/clip.
On the right there are 3 tabs that tuck under the side window.
Once you take the bolt out you are going to pull hard and straight out as you stand directly behind the truck to get them off.
Here is what it looks like under them.
Here is the back side of the stock vent.
The Street Scene smoothies don't have the bottom left tab for some reason so I used 3M double sided tape in its place.
Here are the new smoothies in their place.
thehoe92
fo sho
The916
also if you are real serious about SPL and have a huge system and want to get louder I took mine off to take out the air vent and then I put some Second Skin Damplifier over it so no air was leaking out.
It is a little different now when you shut the doors because the pressure stays inside but it is much louder.
Nice write up I wish I would have seen this when i started.
the key is to pull away from the tahoe in a few tugs.
MASS-HOE'Z71
Mass
is there any downside to getting the smooth caps as far as blocking that vent out, im about to order the street scenes caps but im alittle hesitent, thought i remember something about them being for the rear a/c?
Narco
Atlanta
has anyone just painted the rear pillar vents gloss black to match the paint? i wonder how that would look.
titanium02
w7's or bust.
Norfolk, VA / ATL
I like the vented look over smooth. I keep Back to Black on them so they blend in perfect with the tinted windows.
I do want to take out the rubber flappers.. sick of them farting to the bass.
Narco
Atlanta
did you paint yours black? i want to see what these vents look like painted black,.
PUNKYOU007
Hopewell VA
I know bringing this back from the dead....
Is there any ill effects to covering those so air does not leak? I hate the sound those things make on my truck but I have been leery about covering them. Why are they there in the first place?
PUNKYOU007
Hopewell VA
so I took mine off and removed the vents and covered them with deadner. Color matched my covers while they were off too.
Any way, I have found that removing them and sealing them up have cut down alot on noise outside the vehicle. But...if you are running your air and have it set to fresh air instead of recirculation, there is a good amount of pressure build up in the truck. Its so bad that I can feel it in my ears, now when I run the A/C I also crack one window. Just and FYI in case anyone was wondering.
JamesinAbilene
