Under hood trouble light?
this thing is wankie. I dont know hownit is supposed to work? 4e673142df0f85817b753a6ea52a695b.jpg
Sent from my SM-A505U using Tapatalk
it's a gravity switch, when the hood is angled up it is supposed to switch on, if it doesn't come on then smack it, if that doesn't work maybe the bulb is burnt out. they deleted it years ago most of us now just use a led strip and a hood pin
SnowDrifter
Washington. The desert side not the Starbucks side
i need more information on this i want this on all my vehicles.
4x10w (12v) led modules thermal epoxied to the bottom of the hood. Acts as a plenty fine heatsink. Wire them up in series. CC/CV controller - really should use an LED driver but the local electronical gadget shop was sold out. Set limit to 12v, current to whatever the lights draw.
Wire up, toss in a waterproof box, you're set.
89Suburban
Bull in the china shop
SE PA
drakon543
i dont think a fiber glass hood will work that well for heat transfer. going to look into the rest tho. ill probably opt for something with a built on heat sink or something
hadi awais
