R3cord303
Posse In Effect
Oregon Valley
Yeah, I think it would have been $165 for a standard tint but with the black truck and black interior I wanted something to keep the interior a little cooler in the summer. He quoted $280 for ceramic and $230 for carbon but ended up giving me ceramic for the carbon price.
It's definitely tough to see out of the rear window, but the front windows aren't as dark so the side mirrors aren't obstructed, plus I have a backup camera. My bright LED reverse lights definitely help at night.
Man thats a pretty good deal. I paid I think $250ish for just the eyebrow, fronts, and sunroof. Though its par for the area and they did a pretty fine job. Also used higher quality shit than standard
mattjones
VA
I didn't even think about tinting the sunroof until you mentioned it. I don't really use it that often and when I do the glass is usually open.
I am certain you will catch and surpass me soon enough. The Burb doesn't get driven as much since the wife started driving the '08 Civic to work.
How many miles on your beautiful Burb now?
222k....We put roughly 10k a year on her mostly because it's what we use for vacations and the other smaller road trips throughout the year. If it wasn't for that we'd probably only put about 6k on it a year cuz the wife mainly just stays in town.
R3cord303
Posse In Effect
Oregon Valley
I love to have the cover open but without the additional tint the sun would always shine thru the stock tint and into my eyes. In the summer I love to have it tilted up or slid back but cant really have it open during the day because of said glare issue. Tilted up now is possible because of the added tint
Kee Fuller
las vegas
Hell of a good deal. I paid 500 or 600 for all my windows and windshield in ceramic
Geoffsfas10
St. Louis
Damn I paid 90 bucks for from fronts and a brow. Sunroof was 20 bucks. Im going to have him do the rear 5 windows later this year for 140.
Also...I may or may not have started on my retrofit tonight....which possibly included up to the test fit and alignment of a projector in 1 headlight.
trailblazer
I was thinking that was a lot, too. I high mileage POS doesn't catch anything close to that amount. That's pretty wild.
I knew it was getting bad when I had to use a coffee can to drain into. Next time I’ll try to make a video of draining it after it sits for a couple days. This time of year on my off days I drive my GMT800 plow truck around town and the Tahoe sits for a few days. The oil and water will separate and it’ll drain clear for several seconds before the oil comes out. I should keep all of it in a large glass carboy and then use the water to make spaghetti.
Sam Harris
And I’m hoping you may have a photo-documented reference of said possible mod...
JT 07LTZ
Western, NC
Just finished up a whole bunch of maintenance and repairs that I had been putting off. My tahoe has 140K on it but the engine runs great so I’m going to keep it for a while. I finally decided to finish the work after my G80 rear differential blew up. It’s one hell of a list:
Oil pump, water pump, timing chain, replaced the leaking oil pan gasket, H3 motor mounts, Yukon limited slip differential, replaced both front hub bearings, transmission fluid, transfer case fluid, front differential fluid and axle seals, tie rod ends, spark plugs/wires, cleaned throttle body, replaced leaking power steering hoses, replaced rear brake calipers, pads, and rotors. Replaced leaking brake master cylinder.
Also, I needed tires so I went ahead and got some Fuel Trophy 18x9 and some bigger Duratrac 295/65r18 tires. I wanted more rubber than my 275/60r20s.
D20431C4-902C-4C07-9F8D-65DE7D061A22.jpeg 28A50712-8879-40F9-98AD-0D5AA0EBDE3E.jpeg B12F87B2-C754-49C3-BCA1-4E0CF9F852E8.jpeg
HiHoeSilver
Away!
Chicago
View attachment 240071 View attachment 240072 View attachment 240073
Yeah, buddy! Nice work!
R3cord303
Posse In Effect
Oregon Valley
Nice! How much stiffer are your h3 mounts. I did mine and a cam at the same time so it shakes noticeably more than it used to but how is it on a stock engine?
JT 07LTZ
Western, NC
I feel a little more engine vibration at idle but it isn’t that noticeable. I’m just hoping they hold up a lot better than the stock fluid filled junk they put in these trucks.
What cam did you put in and how do you like it?
R3cord303
Posse In Effect
Oregon Valley
Both the stock ones in mine were shot to hell and back when I got the vehicle. Interior rattled and there was a thunk on acceleration. I hated it. H3 mounts installed and a Texas Speed Low Lift stage 2 were used. They say in a vehicle as heavy as ours, its as big of cam as you can run without a higher stall converter which is something I wasn't willing to do. They say its supposed to be a 50ish hp gain at the crank which is about the neighborhood I'd fall into. I don't have a before/after but I did make 295 whp on a 92 degree day on 1/3 of tank 87 octane and the other 2/3 filled with 92. I'm on a 2007, so no vvt. The cam is great. They claim below the curve gains are up to 70 more hp vs stock which I think might be a little much, but damn if it isn't a kick in the pants. The vehicle "comes up on the cam" above 3200 which I wish was lower, but you sure as hell don't loose power down low from stock. Basically, it feels like the trucks got vtec now. I also got rid of my cats, so any slight- and boy do I mean slight- hesitation happens right off idle. Its probably a combination of the cam and going catless, and the fact that I need to change my ATF all stacking on top of eachother for the hesitation. Its not noticeable to anybody but me, but YMMV.
The cam made my tahoe faster, no drop in MPGs which almost pissed me off, and it also sounds pretty cool at idle.
Sam Harris
That sounds great! I’m adding this to my list... only worry is I don’t want to lose any bottom end.
R3cord303
Posse In Effect
Oregon Valley
above 1200 which is the stock stall speed you’re not loosing any. Esp if you are still emissions compliant.
if you have the 6 speed and/or 4.10s you won’t be able to tell I don’t think
Sounds great.
Escalade2007
