Powered Tail Gate failed
NorCal
Hi,
My powered tail gate door does not work, when I press the button on the remote the motor does kick in but it does not raise the door so I have to open it manually.
When opening it manually I need to pause once it has opened a little bit and then it clunks and I can then open it the rest of the way, I am not sure if that helps the diagnosis.
I assume it needs some replacements parts and I wonder if the fix is doable by an amateur like me?
Thanks
Hi,
Thanks
Replace the other lift struts and see what happens.
wjburken
Eastern Iowa
Hi,
Thanks
You may have a broken gear in your liftgate motor. Here is a link to a post discussing this issue.
https://www.tahoeyukonforum.com/threads/back-lift-gate-motor-not-working.114943/#post-1383401
2007 Denali XL
NorCal
Take a peek through the lift arm opening and make sure it is still attached to the motor output.
Yep, its all attached.
I can open manually by pressing the opener on the tailgate. I have to wait for the door catch to open and then I can lift it open a small amount, I then have to wait for a clunk sound and then I can open the rest of the way.
It seems like the motor is not operating at all.
I will take a video of the opening process and post here
wjburken
Eastern Iowa
I don't think its the struts as the motor is not even trying to lift the tailgate.
Here is a post with a video on the topic
It could be a couple of things.
Your first post stated that you can hear the motor running but no action so that eliminates the possibility that your liftgate switch is turned off and it indicates that you are getting power to your motor, or so one would assume if you're hearing it.
The linkage could have come loose which you can try and check by grabbing the lift rod and seeing how much play you have.
I believe there is a clutch on the motor and those sometimes fail.
There are also a gear train that can strip out and if your gas springs failed, it could have overloaded the gear drive and stripped a gear.
Here is a video that discusses how to get to the motor. There is a couple things the guy covers at first but around 2:45 he gets into the lift motor.
wjburken
Eastern Iowa
Thanks, I have watched this a couple of times now. What is not clear is was the lift motor faulty or was the door latch fault causing the lift motor to not engage
thoughts?
I think the guy in the video had a bad motor.
Thanks for sharing this.
Does you think if the struts are faliing it would impact the door motor activating?
I dunno, don't have it but thought the video was intriguing. If there is not enough support from the struts, maybe the motor senses too much resistance and doesn't work to preserve itself. I dunno, but changing out a strut is cheap and easy.
2007 Denali XL
NorCal
thanks, I am going to try that and will report back on the outcome.
2007 Denali XL
NorCal
Replaced both lift struts but has not fixed the issue. The symptoms remain the same, I am unsure if I should tackle the lift motor or the switch/lock on the tailgate.
The later seems to be working as I can operate it manually therefore I think something is up with the lift motor itself
Ok, and you do not have a Tech-2 or VXDIAG NANO? Either of those or a Snap-On bi-directional scan tool will identify the problem right quick. I've got a dumb tailgate, so no experience with them.
2007 Denali XL
NorCal
Here is a couple of vid showing the action from the tail lift motor when I press the button on the tail to close it.
BG1988
the motor is broken..
try applying 13.5Volts directly to the motor..(make sure the polarity is correct)
Hodmjstone
