2015-16 had air conditioned seats. 2017 on has only "vented seats".thanks guys appreciate it, anything else?
Yeah, not so sure about it being "the same". The design did change substantially between 16 and 17. My current 19 is the same as 17 and on. The ventilation is much less robust in the newer models and although at this point I can't be certain that there was no AC ducting to the seat it sure felt cooler, but maybe due to substantially less air volume.It's the same thing they just changed the wording because people were expecting actual air conditioned seats and not understanding the air inside the truck has to cool down before the air coming through the seat can cool down.
This is true. The earlier ones, like the GMT900 had a TED that DID cool the seats in the unit itself. Current flowed over an element in one direction making heat, and reverse flow to pull heat out if the element making cool air. On a 100 degree day, with JUST the seat cooler on with engine off, the seats blow cool air. Maybe they changed something over the years or on the K2 plafltform.There is no AC ducting to the seats in any year.
Good info! That might also explain why the heating function in the seats was only so-so. On my 2019 the heated seats will fry your ass!This is true. The earlier ones, like the GMT900 had a TED that DID cool the seats in the unit itself. Current flowed over an element in one direction making heat, and reverse flow to pull heat out if the element making cool air. On a 100 degree day, with JUST the seat cooler on with engine off, the seats blow cool air. Maybe they changed something over the years or on the K2 plafltform.
No massaging seatsThis is the info I’m looking for. Anything else? I read about massaging seats when did they appear? I had a ‘15 SLT and ‘16 Denali and looking to get back in another Denali. I’ll consider older ones if I won’t be missing out on new features.
