Need to find genuine OE part number for Delco oil pressure sending unit
Sam Harris
And I posted in the wrong section dammit. Need this moved to the 2000-2006.. sorry
Hey guys, so when I bought the Yukon it had a bad pressure sensor. I replaced it with a standard, since I broke the top off the Delco one I had bought. Lol. The standard failed catastrophically in about 3 months, actually leaking oil out the top! So I replaced again with an “OEM” AC Delco part. This part also failed after about 6 months and was replaced under warranty. So I’ve had the current unit in for less than 6 months, and guess what? It’s pegged again. The Tech2 reads 4.59 volts back from it, which explains why it’s pegged at 80psi. Thanks to @Fless for checking his for me, it seems to read under 1v consistently. 3e313ed3bf5dac8888c7960e584652ca.jpg
So I want to replace it again, and ensure I’m getting the OE Delco part, not the pro line, or anything else. I know there are 3-4 Delco lines and after all these failures, I am tired of it breaking. If this doesn’t do it, I’m thinking the wire harness to it may be faulty, so a part number for that would be helpful as well. Any help from someone who has a good idea of the different AC Delco lines would be very welcome!
Super Moderator
Elev 5,280
Sam,
Have you looked it up at gmpartsdirect.com or another GM parts web site? If not, go there and enter your VIN, then "electrical", then "senders". My L59 is similar to yours but something might be different for yours, so best to use your VIN. Here's what comes up for mine:
https://www.gmpartsdirect.com/oem-p...vPXRhaG9lJnk9MjAwNCZ0PWx0JmU9NS0zbC12OC1mbGV4
It shows superseded part numbers, too. Just be wary of non OE parts that reference only the GM part number, and not their own. They should xref to the GM number but it should be obvious that they're not the real McCoy. Should be able to find OE on Amazon. Hope that helps.
Sam Harris
Sam Harris
Sam,
Thanks Fless. Yes, Amazon is where I got the first one. I just want to be sure it’s the real deal. I’ll look at gmpartsdirect as well[emoji106]
Sam Harris
Sam Harris
Sam,
Yep, here’s the original one I was installing and managed to break off the plastic top piece. [emoji2957]
Super Moderator
Elev 5,280
That stinks! Hope I never have to change mine, but if I do, I know you are getting all this experience and I may have to get up there and visit you! A little drive across town. LOL
kbuskill
NE. FL.
Are you swapping these yourself?
Is it possible that they are somehow being damaged during install?
Just seems strange.
Sam Harris
Sam Harris
Haha, for sure!
Sam Harris
Sam Harris
Just seems strange.
I did the first one, then I had my buddy who owns a shop do it. I have faith he’s not bunging it up during install. And forgot to mention, I also have a new / rebuilt cluster the last 6 months or so as well. Pretty confident it’s not the stepper motor this time around, especially seeing the voltage where it is.
Off Road Pedia
