2015 Tahoe lowered on Belltech 2/4 rear sag
Trides
Alberta
I got the 2/3 and it’s slightly higher in back. I think you can use a spacer to raise it vs buying new springs or dropping the front more.
Big MaMa
Are you talking about lowering your 2007 Yukon and comparing it to a 2019 in this thread?
Big Mama
Virginia
Big MaMa
No, I was comparing what I have vs the 2/4 kit and offering an option to buying new 3” springs thanks
Trides
Alberta
Belltech store shows 23323 and 34324 springs as 3" - 4" rear drop and the 5321 as 2", what's the part number for Belltech 3" rear spring you speak of?
Rideoutdenali
Hello new here.
What were some of your fender heights before lowering?
I have 3”rake on my 2015 Yukon Denali. I’m looking to do a reverse level or maybe 1” drop in the front but not sure if I should go 2”or 3” drop in the rear.
Front fender is 34.5” and rear is 37.5” as it sits.
Thanks
Big Mama
Virginia
If you want it level 2” in the back does a nice job. 3” makes the rear lower but if you plan on dropping the front later get the 3” springs and 1” spacers. When you decide to drop the front just remove them.
wjburken
Eastern Iowa
Hello new here.
Thanks
Welcome to the forum.
Rideoutdenali
Thanks
Which 3” drop springs do you recommend that come with the spacer?
SDHanz
