2005 Tahoe Daily [Update 06/25/20 - leveled?]
Galandorian
Galandorian
Albany, New York
ended up impulse buying some other subs, so it looks like I'll be going with 15s instead
I had this box built last year for my Denali, and ended up selling it before using it
so now I'm paying out the ass for another builder to do it this year lol
big financial mistake
anyways, got a cool pic of the headlights and a little video of output
really hard to gauge output on video since my windshield tint is so dark
Galandorian
Galandorian
Albany, New York
got the new setup in
3 Sundown ZV3U15s on two Wolfram 4500s @ 0.33 each (eventually) and a Brand X 270a alt and G30 Limitless Lithium battery
only have one amp hooked up while I work out some electrical gremlins regarding my charging voltage (charging at 15.2v but desire 15.6v - 15.8v)
if I end up keeping this setup into Spring, I'll take everything out and stain the box and make a better battery cover... etc
Galandorian
Galandorian
Albany, New York
on a whim over Black friday I picked up 4 VFL 18ks and 4 Godfather 15s D1
huge 4" coil subs and a lot more power on tap..
my head unit took a dump and I got a new one, but still having issues with Pioneer ground whine.
hopefully testing out the new setup tomorrow after work and deciding where to go from there.
Thatsquishykid717
Annoying guy with the loud stereo
eventually got my voltage figured out and started charging between 15.8v - 16.2v:
and got one video of the setup before I started pulling it all apart lol
taken after work one day so it was pretty much dark already :(
Is it bad that I remember you because I recently saw your post with those zv3u15s for sale? Certain things you can remember people by like some sundown frankenwoofers
:laughing1:
Galandorian
Galandorian
Albany, New York
:laughing1:
Haha yeah they're sweet subs :) I still have them and will probably throw them back in here once I get some clamped numbers.
I first remember seeing your stuff back when I also had 6 12s
Sam Harris
:laughing1:
That liftgate action was pretty sweet. [emoji1787]
Thatsquishykid717
yeah you change setups a lot lol I still have the 6 12s lol. Probably will stay that way for now. If you lived closer I probably would have bought some of your old enclosures to try new setups with cause you usually let em go for a steal
Galandorian
Galandorian
Albany, New York
yeah last year when I had my midlife Denali sunroof crisis I was giving boxes away lol
had 3 built for like $300-$500 each and sold them for $100 each ;/
live and learn
current setup is getting nastier :)
I wanted to clamp the VFL 18k today but it was so damn cold (15 degrees before windchill)
someday soon maybe
I also "accidentally" bought a pair of 12ks and a big 4 channel from a buddy who became a Taramps dealer recently
Thatsquishykid717
Hell yes that does look like it’s getting down. Had it on the meter yet? I’m still trying to break 155 sealed on the glass with mine which I’m only a tenth away . It’ll do 155.4 in the kick though. Need to get my 8” Aeros ordered already to swap out the 6’s
Galandorian
Galandorian
Albany, New York
yeah it sucks on the meter
like 151s sealed, 152s with the driver window down
one of these days I need to clamp my amp and then adjust a new box and subs accordingly
Thatsquishykid717
yeah understandable. Last time I clamped mine it was 8500 watts out of both 5ks at .33. I have lots and lots of rise lol.
Galandorian
Galandorian
Albany, New York
Pretty disappointed with the clamping of the 18k, only seeing around 11,000w max:
got plenty of other amps to swap though. :)
I just met with my builder and dropped off a down payment for new doors (2 12s, 1 horn, 1 tweet per door) and then also a new box, going with 4 15s this time:
and I've kept track of all the miles and fill ups I've done with this truck, whooooosshhh.
gotta find a new daily
you can see on the trend line where I added the 2nd alt, BFG tires, and bumper. MPG took a dump
spent 25% of the cost of the vehicle - on gas so far in 6 months of ownership
Thatsquishykid717
rising to 1.1 ohm at 49hz and only clamping 10579?! Were you dropping voltage pretty bad or does it just not do what it’s rated? I feel like for a 18k it should be able to at the very least put out 15-16k at 1ohm.
Galandorian
Galandorian
Albany, New York
swapped back to my Sundown subs and made the switch from Korean to all Brazilian amps
much smaller footprint, less wiring, easier to fit
my rise doubled, and my power stayed basically constant, while my dB rose
Galandorian
Galandorian
Albany, New York
Since I got this vehicle, I guess I never tested the windshield wiper fluid
went to use it the other day, and nothing happened
took a look, and I was shooting juice all over the garage
I noticed that my battery was all soaked, and then found out the line had failed at a fitting
so grabbed some line and fixed 'er back up
as good as new :)
ivin74
05 NBS Nali
Htown, Texas
What app is that?
vdesolution
