Drive Belt Tensioner Noisy. Replace Whole Unit or Just Pulley?
Ex Euro Driver
Happy Holidays guys. Got a hissing drive belt tensioner and wondering if I can replace just the pulley or do I have to do the whole assembly? Thanks
wjburken
Eastern Iowa
You can replace just the pulley or the full assembly. Looks to be about $25 difference between the two options at RockAuto.
I recommend that you replace both parts, as the tensioner spring within the bracket assembly loses its strength over time. I replaced my AC tensioner pulley and tensioner bracket assembly recently, as my spring broke, and I bought it from Rock Auto. The job to replace them is simple. Depending on how old your belt is, you may want to consider replacing the belt at the same time.
trailblazer
I have owned about 10 trucks with the LS motors and it has been 50/50 on finding a pulley spring that was jamming up. I’d do the right thing and replace the entire assembly. Be done with it an but the gates belt component kit from RockAuto (don’t forget the 5% coupon code). The A/C belt isn’t a real priority unless it’s making noise.
petethepug
Michael
SoCal
Prudence says do it all, just once. I just lost a drive belt right after exiting commuter traffic next to Disneyland. I made it through the traffic light at the end of the ramp, then the belt fell off. It was an 08 Denali XL.
With five kids in the truck I simultaneously lost steering and the coolant began to steam out from the tank from overheating. With motor off I lost power to brakes. I got lucky and pulled into a parking lot. AAA f’d me and made me wait 3hrs for a tow a block away from a **********. At dusk the hobos came out and had to Uber all the kids to the park where the wife was.
Those pulleys and tensioners are critical to these trucks. Mine had just been replaced and also had a new belt. Shit happens, it fell off. Thankfully we took two cars because, even with a 2nd row bench seat, we were one seat belt short of getting 8 people in the Denali XL. Fortunately my wife was already at the park with another car to receive all the kids.
Ex Euro Driver
Ex Euro Driver
Dang Pete, that’s a rough go. Glad you got through it. I had already made up my mind to do both pulleys and drive belt but now there’s absolutely no question. I put miles on my truck and depend on it. Hopefully she doesn’t let me down.
Derick
Indy Suburbs
I agree....the assembly is the way to go....3 bolts, 20 minutes and you're done.
Derick
Indy Suburbs
If you're going that far, might as well do the AC tensioner and belt too....
Seamus
Palm Beach
I just did mine not long ago. It's a pretty easy straight forward job. You know that AC belt will go on the hottest day of the year right?? LOL I did the tensioner pulley, pulley, serp and AC belt, less than an hour. Youtube is your friend if you have the stretch AC belt. Zip tie or tool takes 5 minutes. Do it all while your there, it's cheap and easy. Good luck
intheburbs
SE MI
From a catastrophic failure standpoint, if the tensioner seizes, it takes out the belt, too. Ask me how I know. Fortunately, when it happened to me, it was the A/C tensioner, not the serpentine tensioner.
And I don't mess with the A/C belt/tensioner as part of my regular maintenance. Too much of a PITA. When it breaks, then I fix it. A/C is not critical to the operation of the vehicle.
koomie98
