2000 Yukon-Long warm up time - partial heater core restriction possibly?
wjburken
Eastern Iowa
it's true it was warmed up once I got to the main street down the road 2 min away plus 1 min closing the gate
electrical A/Cs can in fact cool faster then a normal mechanical A/C.. is that what your mad about?
nothing magic about it it has way higher cooling capacity then a mechanical A/C.. there for can cool faster.. how is it magic when it takes less 30 seconds to start pouring out cooler air while your mechanical a/c takes much longer as it has less capacity and takes longer to circulate the tube to the rear a/c why do you think it takes 3-4min? to start cooling down?
also btw this Tahoe takes forever to warm up if that matters to you as there is nothing on the pulley(except for a water pump) to add additional load to the engine
1). I’m not mad about anything, just poking a little fun.
2). All my vehicles have electric fans.
3). We are talking about heating up so not sure why you are discussing A/C and cooling capabilities.
4). I had a 2002 Impala and no way it warmed up that fast.
That being said, when I think about warming up a vehicle, it’s when it’s 15F, or colder, outside.
BG1988
That certainly addresses the OP's question about these trucks.
what i did answer it
right at the end it says
Super Moderator
Elev 5,280
And yours is a hybrid, right? Two different animals.
BG1988
it was quick as i did the oldest trick in the book to warm it up faster by turning everything on.. this will place additional load to the engine there by warming it up faster... you probably had air in the system from faulty elbow heater core lines. i replaced mine with metal ones
liquify33
Houston
Have you checked for proper/full coolant level? My first sign of a coolant leak was a cold heater trying to defrost windows.
Danno34
Trying to get an idea for what the typical time it takes while driving to get the engine up to temp.
My 2000 yukon seems to take a while to get up to 195 at least and the heater performance kinda sucks especially at idle.
Its been in the upper 10's to upper 20's here lately.
I actually think I have either a combination of 2 small problems or just a partially plugged heater core. If I drive roughly 7 miles to get to the highway usually going 45mph with the occasional stops (so about 12 mins). The temp gauge just gets to the 1/4 mark. Generally have the rear and front blower on high and temp all the way high.
Just never really gets good and warm in the truck. Its barely mild at best. Temp gauge does get up to the 195 right before 210 mark just takes a long time. Heat in city traffic sucks, you can feel the vent temps cool off when at idle and they warm back up when accelerating.
There really isnt any good heat until it finally gets to 195.
I think the heater core is the issue, perhaps partially plugged? Coolant level is good, there are no leaks. Thermostat was replaced by previous owner and there are records of the heater core being flushed and it states in the records that he's had this lack of heat issue a few times
What do you guys think? how long does warm up typically take for your truck?
What you just explained is EXACTLY what was going on with my truck as well. I have a 2005 Yukon Denali XL. While everyone else’s responses is necessary to rule out (as I did) the ultimate issue is that the water pump needs to be replaced. Your truck is losing antifreeze and the pump isn’t doing it’s job by recirculating the coolant. I just replaced my water pump yesterday (also the thermostat even though it was fine figured why not ) and I replaced the upper radiator hose. My Yukon now heats perfectly. Only takes a few minutes to warm up on a cold morning. Interior heat is nice and toasty now. If you replace the water pump all of the issues you explained will be resolved. It’s an easy fix and you can easily do it yourself. If you have an Advanced Auto Parts Store near you use a 25% off code online to buy water pump and then pick it up in store. Not expensive at all and it’s a very good quality part.
Super Moderator
Elev 5,280
The OP said the coolant level is good and there are no leaks.
U
UmmScott
Omaha
Yup. He's an HVAC/HACR guy, too. I trust him. ;)
I mean..i could be crazy and not seeing something LOL [emoji23][emoji23]
But i will for sure double check. If my water pump wasnt pumping correctly then wouldnt i have overheating issues? It was great this summer and i took the truck to colorado this fall and had zero issues there.
Sent from my SM-G975U using Tapatalk
DefiantOne
