How do I remove Esky mirror cover?
I thought some models they slide up. Is there a chance of breaking the retaining clips if pulling too hard or if the plastic is cold?
There is always a chance of breaking the tabs as well as the mirror itself if you’re not careful. I have done it a few times without an issue. I adjust the mirror to the position that gives the best access to the back of it and use a plastic pry tool to get behind the backing plate to get it started then get my fingers in there. When you get it out far enough, disconnect the wires.
Ep33401
