Rubber Tube came loose underneath body.
BlackYukon
I'm kind of a Retard
Noticed this morning there was a rubber tube hanging underneath the vehicle near the transmission. I assume it's a drain tube? But can't for the life of me figure out what/where it connects so I can put it back in place. Didn't see any place on the transmission for it either.
Any Help would be very much appreciated.
that's a vent tube for transmission there should be a nipple it fits on up top, you may have to get a flashlight and mirror to find it and put it back on
Big Mama
Virginia
I wondered where I left that...Also a clamp if called for or new hose. They usually come off for a reason.
Multnomah Falls
Military
I can't see any clamp marks on the end hanging down so it likely did not have one. If it is a vent hose they usually have a one way valve in the other end. If is blowing the hose off, and not just falling off for some reason, then there could be a pressure problem causing it. I am not a trans "know it all" so I am guessing at this. If the pressure is a concern there may be something internal to look for.
this should give you some idea presuming it is the 6l80, looks like it maybe "T"'s to another hose?
at any rate the actual vent is up by the shell passenger side
Pepper1700
