Show off your 2015+ leveled Tahoes and Yukons!
Tiki
Tiki
Trying to decide between 275/70R18 and 285/65R18 KO2s. Feel like either setup rubs or doesn’t rub deciding on who you ask. If it were my truck I wouldn’t mind, but the Suburban is our vacation mobile and needs to be as reliable and sensible as possible.
olyelr
Elk Rapids, MI
Either would be reliable and sensible options.
I personally would go with the 275’s.
Bryingram4
San Diego CA
I don’t have any good pictures yet since the transformation from lowrider to lifted.
I ditched the 2/4 Beltech drop kit and Giovanna 24” Wheels along with the MRC and Auto Level. It looked great lowered and actually drove great. But as soon as my MRC shocks started loosing oil and riding like crap, it was time for a change.
So I did tons of research on here and based off my findings, I went the obvious and best route, in my opinion.
I did the BDS lift with Fox adjustable compression rate coilovers. The shocks are also height adjustable so don’t think you’re stuck with just a 4” or 6” lift, you can adjust them to do whatever you want/need. I haven’t measured but I know for sure I’m around 5” over stock.
I did the 3” rear kit from BDS in the rear. You can choose between 2” or 3”. The 3” is actually a kit that relocates a lot of things. The 2” is nothing more than a 2” spacer. I also went overboard and replaced the OEM Yukon XL Denali coils with New OEM Z71 Suburban rear coils. Figured why not?
I replaced the upper control arms with a machined high performance arm from Mazzulla Offroad.
The wheels are Method NV 20x9 simulated beadlocks.
The tires are Toyo Open County M/T 35x12.5R20
With all this weight the factory brakes have no chance in actually effectively stopping me so I had to upgrade to the best option there too. Went with Wilwood 16” Rotors and 6 piston Calipers out front and 14” Rotors and 4 piston Calipers in the rear. Would have 16” & 6 all around but they don’t make it. Overkill I guess.
I had to do some trimming and adjusting to actually fit the 35’s without going 6” or higher in lift. The automatic steps were adjusted and moved back. Nothing crazy or too obvious. It’s all very clean.
It rides and works amazing. Couldn’t be happier. I highly recommend doing it all. It was well worth the $$$
Dave Legacy
I run a 265/70-18 SL Falken AT3W. Same overall diameter as the 285/65 and no rubbing whatsoever ever with a RC 2” level.
I never see anyone run this size, but to me it was a no brainer. I had similar criteria to you.
sanman28
2” with Nitto Ridge Grapplers 275... hopefully KO2’s don’t look skinny...
275/70's?.... I have 285/55/22's on my leveled sierra and they rub on moderate turns both fwd and reverse. Im afraid the z71 18's will rub bad with the 285/65's and a level.
K2 Kaiju
The Depths
Do these rub at all? Im looking at these exact tires but on the LT 18" wheels - not sure if they have different specs than z71 wheels. Also debating need for E rated tires - the burb is on road way more than off, and I rather enjoy the current buttery ride...
Sent from my SM-T580 using Tapatalk
HiHoeSilver
Away!
Chicago
Here's one stock on 18s reporting no rub...
https://www.tahoeyukonforum.com/threads/285s-on-a-2017.89434/#post-1088645
I am running the same wheels on my NBS Z71. Just did 275/70r18 Grabber ATX. No rub.
HiHoeSilver
Away!
Chicago
How do you like the Grabber ATx?
So far, so good. Very quiet. I didn't expect them to be loud, but there is literally 0 road noise.
They ride great, and have been very surefooted in the bit of snow and wet we've had thus far.
STX30MAC
I am thinking about adding the Rough Country 3.5in coilover with upper control arms and deleting Mag ride in the front. Leaving the air shocks in the back with 1.5in coil spacer so I can level the back to match front.
26AT4
