Passenger Door and Dome Lighting
morales99
Houston
Hello everyone,
I am having an issue with my dome lights. They turn on when I open every other door except the front passenger one
Does anyone know what it could be or provide some input to figure it out?
Thanks in advance
Sent from my SM-N950U using Tapatalk
i think you could do a basic test of the door lock sensor by having a helper and then be driving about 15mph and have them open the passenger door (while driving), if you do not get a door ajar warning then it's probably a bad door lock but it could still be bad even if the lights do not come on and the warning does.
M
morales99
Houston
I have actually done something similar and I did not get the warning, thanks!
wjburken
Eastern Iowa
Im having trouble locating it by the name for this year truck, is there another term so i can try to locate it?
Thanks
Rockauto has them. You didn’t mention year make or model but this should be close.
Search under your year, make model and then go to Body/Door Latch Assembly.
CKendrick
