In short, yes.
The only way I can see sway bars making a difference in "ride comfort", assuming that means normal, straight-line driving, is when hitting any off-angle bumps/dips that would cause one side of the suspension to be at a different height than the other. If you were to hit something squarely that spanned the roadway, such as a blowup or speed bump, and both sides of the suspension cycled the same amount and at the same time, then the sway bar would have no affect on the firmness.
But, there are transfehardly any instances where you'd encounter such irregularities on the road. Most are a dip or bump, slight low or high spots, etc. that only one side of the vehicle rolls over or at least one side is affected more than the other. Anything uneven left-to-right is going to affect the other side. That's what sway bars do- they connect the two sides. A stiffer sway bar will make this uneven cycling more noticeable since it will transfer rather than reduce the absorption of the cycling. But, in my opinion, it's not enough to outweigh the benefit of the stiffer sway bar(s) when cornering.
As far as nosediving, I don't see how stiffer sway bars could affect this, either. If you were driving straight and slammed on the brakes, both sides of the suspension will cycle the same direction, at the same time and the same amount. Both ends of the sway bar would swing upward at the same time and the same amount. If you had both end links of your sway bar disconnected, you could swing the bar up or down easily with one hand with very little resistance. During a nosedive, the suspension cycles the same way, only it's a control arm on each end pushing both ends of the sway bar up instead of a human hand. The bar still has very little resistance. Now, any off-angle nosedive, such as when swerving and slamming on the brakes to avoid a collision, a stiffer sway bar would absolutely make a difference.
I believe the engineers specified a sway bar that struck a balance between resistance to body roll and side-to-side compliance. This decision also had to suit both the purpose of the vehicle and the average operator of the vehicle. There are always people that, based on their personal preferences due to driving style or environments (mostly smooth or mostly rough roads,etc.), would want something a little firmer or softer.
