Replacement door handles?
Denali2k8
Any certain brand or vendor? 2 out of 4 door handles need replace as they are breaking off so I might as well go ahead and swap the whole set.
Dingus mcghee
I've got the same issue. I just ordered an lmc catalog.
I couldn't find any other information.
I've got an 07 denali.
Outside? What's wrong with GM OE?
Chrome or Black? Double check these numbers as I do not know if the rears are different for a short truck, mine is an XL.
akbrener
Baltimore, MD
are those painted black or textured black #s? still not sure why they used white plastic to mold them. sticks out like crazy on the inside where the paint has worn off.
Definitely want OE unless you want to replace them constantly. Aftermarket ones break super easy.
Denali2k8
Denali2k8
Where is the best place to order OE parts? I just need 2 of the 4 handles currently.
mattjones
VA
GMT800 2005 Tahoe Z71
Navy Supporting Member
https://www.gmpartsdirect.com/oem-parts/gm-handle-outside-84053438
this is what I got googling one of those part numbers. How difficult is it to replace the exterior handle? Am I basically gonna need to pull the whole interior door panel off?
Unless they made a bunch of changes since I ran shops the interior covers have to come off and if you don't care about after market or not, lots listed at rock auto.
If unsure of replacement procedure watch a you tube.
John Root
How much does Exterior Car Door Handle Replacement cost. Hopefully any one can give me a tentative idea. thanks.
Kee Fuller
las vegas
Since you have a Denali, I'll assume you have chrome handles. I swapped the OEM chrome handles on my Tahoe for painted ones and put two of the chrome ones on a friend's 2-door Sierra so I have two chrome handles left over. One was broken in the spot where they always break (still worked) and I repaired and reinforced it with metal. Pics and write-up are somewhere on here. It's way more solid than stock. They're from the rear doors, but you can swap the arms to use them in the front if that's what you need.
I don't believe I'd ever use them. PM me if you're interested.
*EDIT*
Found the write-up:
https://www.tahoeyukonforum.com/threads/the-what-you-up-to-thread.54016/page-4713#post-1341466
General Stalin
Anyone ever find a place that makes aftermarket STEEL handles? I have an '07 denali and I've broke 3 door handles now from pulling on them trying to open a frozen door. One of them I have already replaced once and it's broken again. Sick of these cheap plastic POS's breaking.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I was thinking about making a bolt through mod to the one I will be taking off.... Cant make a chrome plate/stud weldment but I can polish stainless to a mirror finish.
Are you breaking OEM or aftermarket handles?
CKendrick
