2004 Tahoe won't shift, no power, transmission?
BT2019
I have convinced my father in law to sell me his 2004 Tahoe with AWD and Stabilitrak. It was parked on the grass for 3 years. With a new battery and filling up the tires, the engine just purred, even with old gas. When we took it out for a very short test drive, there was horrible noise from the front brakes and she acted like we were dragging an elephant down the road. Meaning when I took my foot off the gas, it immediately slowed right down to a stop.
We assumed the front brakes were locked up. When we parked and checked them, we found the power steering line had a leak. When we topped it off all noises went away and she turned just fine. When we took it back out, it just wouldn't shift out of first gear, but would manually shift ok to 1-2-3. It still felt like the brakes were locked up. And we only had about 15 seconds in drive before the power steering was empty again. Transmission fluid levels are ok.
Since it was pouring rain, we gave up for the day. We are hoping that best case the parking brake or rear brakes are locked up, worst case, it has transmission problems.
Any suggestions? Is a leak in power steering somehow tied to transmission?
avalonandl
Troy, MICH & Naples, FL
You need to put the car up on jackstands and go through all the brakes- unfreeze them and bleed.
You have a busted PS line. Look for fluid dripping spraying= probably at joint of Flexible to hard lines or at pump.
3 years sitting on grass.... not good.
B
BT2019
Yes. Thanks. We found the leak in Power steering quick. My confusion is, could the leak in PS somehow be tied to the transmission not shifting? I don't think we ever got enough momentum to really shift on its own if it's brakes being locked is the problem. Brakes I'll fix. If bad transmission, we might just retire her.
Fakes should have no effect on the trans. Have you checked the trans fluid condition and level?
No, it's real Mark lol!
Damn you autocorrect!
Chris2144
Ok back up for a second. Trans shifts are dependent on multiple things speed throttle input load are the main one if your brakes are dragging as bad as you say I would bet the trans doesnt want to shift because of the extra load. I say this also because you stated that it will manual shift fine. I'd be willing to bet once you fix the brakes everything will be fine. The power steering is not related to the trans. That will be another repair. Frozen calipers are pretty common and can be had pretty cheap at the parts store
Thauber
Columbus, GA
+1 for what Chris said, if you are pushing it to make it move, then trans will act accordingly by staying in low gear. Any warnings on DIC, such as "Traction Active"?
Press the top button on that AWD selector to the left of the cluster while in park to shut off Stabilitrack and TC (traction control), and see if there is any difference at all.
Have you checked fluid in the front differential and transfer case?
a dirty MAF (mass airflow sensor) can affect shifting as well, before you take it for another spin put a new air filter in it and clean the intake and MAF, pretty easy to do, you can find the cleaner in a spray can at the auto parts store should be $2-3, throttle body cleaner is slightly different but is also $2-3 for a can, take the plastic air intake off and just clean up the maf it comes off pretty easy, also clean the throttle body it can stay on the intake you don't have to remove it.
B
BT2019
Awesome feedback! Thank you. We don't know if the brakes are locked up, since we gave up troubleshooting in monsoon like rains. If it isn't the brakes, I had the concerns over the transmission. We'll try some of these suggestions if the brakes check out OK. I sure appreciate the tips. I'm really hoping for good luck tomorrow and drive her back home.
Agreed brakes could be the problem. I had tried to say the PS leak would have no effect on the shifting. Good luck and let us know what you find.
shegarty
If your truck is equipped with Hydroboost brakes (my 04 Burb with AWD and Stabilitrack is) the PS system is used directly to power the brakes as well. If you are losing pressure your brakes will definitely be effected. Its also possible that the vehicle can sense the drop in pressure and is limiting power due to lack of braking capability. Find and fix that leak and then do a proper bleed on the PS system, there's lots of resources here on how to bleed the Hydroboost equipped system.
GS Audio
