Autoride bypass
need-for-speed
The front is only an electronic damping system; the air is only for load leveling in the rear. The complete system consists of electronic damping at all 4 corners and rear load levelling. Some consider maintaining Autoride as keeping the load levelling, while others think if you don't have the damping you don't have Autoride. You can disable front damping, rear damping or everything. There are normal front shocks that have resistors built in to disable the damping, the same for the rear but maintain the air shocks, or you can manually wire in resistors for the damping. And either run rear air shocks or normal rear shocks.
I think I’ll go with two Arnott AS2700 for the rear. They are a bit pricey but much cheaper than OEM. Will retain the air shock function but not the electronic function.
need-for-speed
So much information, Let me add my noob question. My 07 LTZ 4wd, has z55 suspension. It has electronic shocks in the front and air shocks with a compressor in the rear. Does the z55 also have electronic shocks as standard for the rear built into the air shocks?
Also, looking at the fuse layout a few pages back, mine is an 07, there is no fuse 54 in it, and nothing listed for 54 on the fuse panel sticker. Which fuse in an 07 controls the compressor?
Right now,my front struts feel really stiff, maybe that's just the way they are. On the rear, the air shock boots are torn open and the compressor doesn't come on. No fuses are blown and I have no error codes on the dash. Nothing is unplugged.
Is it normal to have a compressor fail and not throw a code? The rear is standard height still about 2" higher than the front. I would think it would be lower with the shocks blown but I guess the springs must be stiff enough to keep it up, or if the shocks are electronic, do they have fluid in them too and that's what's keeping the ride from bouncing around?
Any thoughts and suggestions or experiences of failed shocks / compressors are appreciated.
thanks,
When I spoke to the guy at Arnott last year, he told me that If the boots tore open on the rear air shocks (which is somewhat common) that would allow moisture into,the air system and that is why the compressor will also fail. He did say the boot on their shocks are made by Goodyear and are much more robust than the boot on the OEM.
outerorbiter
So its been a while since this thread was active. Has anyone figured out if the auto-ride level sensors will need a resistor if they are disconnected? Not even sure if I need to disconnect if not planning a lift or drop that the would need to be unplugged. Just looking to bypass the z55 option front and back. Also does anyone else have any info if the coils in the back should be replaced. I would rather piece my kit together than buying the arnott kit. 2007 Yukon XL by the way
08_crew_cab
Spacecoast, FL
I did NOT remove the sensors, just shocks and front struts. I installed these resistors as previously discussed and no codes for me.
General Stalin
Looking to do this swap in the next month or two whenever the weather clears up. 2007 Denali Full z55 delete, remove the compressor, Bilstein 5100 kit, whole shebang. What's the consensus on rear coils? Folks leaving the stock ones or replacing them for something a little taller/beefier? If so, what coils you recommend? I do tow from time to time.
woody73
I just did mine with new KYB struts and KYB rear shocks. I kept the stock springs but added the airlift bags for towing. Just ordered the resisters today. to kill the dash message. also replaced the upper's with Moog and lower's with oem GM control arms both sides. Rides like new. it is a little bit stiffer in the front. I need to get some miles on it so the springs will settle.
Daturbosix
does this resistance value work to bypass the autoride on the previous generation?
Ricks02ext
Yes, I used them on my 02 Denali.
Hi, hate to bother you but i have had the service stability light on since i bought my truck a year ago, i put resistors it the wires but light is still on, just wanted to know if the resistor goes on the wires that clip on TOP of the front shock, i just ordered the green ones to try again. thank you for your help
Ricks02ext
its an 02 cadillac EXT.
Yes, and also on the rear shocks. You need to do all 4. Cut the connectors off and connect one wire to each end of the resistor.
Ricks02ext
thanks, the rear was done, no light, its the front ones that need them. just wasnt sure what 2 wires it went to.
B2sdad
The Hill Country, Texas
Here is a pic of the ones I used on my ride. Hard to tell if they worked or not until I can pinpoint the problem. I was looking underneath the Suburban yesterday and I suspect the ride height sensors were not shortened ? Belltech supplies a shortened rod that is supposed to be installed to make the sensors approx 3 inches in length from center per the instructions? Mine were never touched?
08grey
I use a regular gold 25w led resistor on my 04. You canget them on ebay or in pepboys.
Sent from my SM-G973U1 using Tapatalk
General Stalin
Swapped out all 4 autoride shocks for Bilstein 5100's over the weekend and soldered and sleeved 4 of these resistors onto the sensor wires:
https://www.amazon.com/gp/product/B07H7CZLZB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Still getting "service suspension system" error but I don't think it's because of the shock sensors. Pretty sure it something to do with the compressor itself (compressor exhaust to be exact). Anyone know if it's possible to just completely delete this component from the ECU using a programmer?
Also would like to ask anyone who has experience with the Bilstein 5100 install - does the front "settle" at all over time? I adjusted them as tall as they would go and I'm riding slightly higher in the front than the back. It doesn't look terrible but I'd obviously like it to be even. If it doesn't even itself out after 1k miles or so I'll probably buy some spacers for the rear coils to level it out.
EDIT: Here's a pic for reference:
JT 07LTZ
Western, NC
I did the same thing to mine and the service suspension light wasn’t on. It came back on about 6 months after my install and I haven’t been able to get rid of it since.
As far as the leveling issue. You have to swap the stock auto ride rear springs for stiffer springs. Stock autoride springs are softer than standard springs. I used the Moog Z71 springs on mine. They worked great.
I ended up adding a 3/4” spacer in the rear to get a little of the factory rake back so I don’t have any Cali lean when I’m towing.
General Stalin
I used the same springs in the rear (https://www.amazon.com/gp/product/B00498ZR7A/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1), but with the front strut adjustment put all the way up to the top setting I think I overcompensated so I may need to do the same that you did (3/4" spacer) to get the rear to level out. that would be far less of a pain in the ass than pulling out the front shocks and taking them apart again to change the adjustment.
JT 07LTZ
Western, NC
Yes I would definitely just do the rear spacer. It’s so much easier
okfoz
I bought one of the compressors from Amazon, and it has a lifetime warranty, on my third one, but oh well, it takes me about 30-60 min to swap it out by the time I get the car up in the air and the wheel off (makes it easier but not necessary)
Charlie21ny
