Oil Pressure
John Snyder
so i filmed a video of acceleration, constant gas, and took a photo at a red light is my oil pressure normal? I just got my oil changed I have 100,000 miles on it its a 2013 5.3 videos wouldn't load but idle was between the 20 and 40 mark around 30-35 and when i get on it it can go past 40. this pic was from the stop light. Also my tahoe has afm/dod turned off.
it is normal for the oil pressure to fluctuate on these trucks, but it shouldn't be going down to low enough to set a oil light, you can load videos to youtube and then put the link in here.
Sounds normal to me. LMG engine, right?
JC 707
I just picked up a 2019 tahoe and was just looking this up in the owners manual! My other vehicles the oil pressure gauge stays constant but this tahoe had me all worried as the needle would move up and down depending on if I am stopped or accelerating. Per my manual it states it is normal.
John Snyder
John Snyder
oh ok cool thank you
how do i check that?
it has the yellow gas cap but there is no flex fuel badging and I haven't run e85 in it since ive owned it
In the glove box is a sticker, your RPO Sheet, with all the codes or options your truck is equipped with. It will show probably show LMG and you can also see this on the emissions sticker under the hood. Ethanol is cool to run the engines love the stuff, free horsepower. I run it when it makes financial sense to or just for the extra power. Mine gets its best mileage on low alcohol percentages, between 15% and 20%.
Your engine has a variable displacement oil pump, pretty cool tech that is worth looking up and learning about.
John Snyder
John Snyder
cool so if it is LMG which it probably is then the oil pressure i described and sent in that pic are normal?
John Snyder
John Snyder
It is an LMG i found it in the glovebox
Yes, once hot, after driving a while, it will drop into the 20s on the gauge at idle or stopped at a light. I forget exactly but the bypass spring on the LMG is somewhere in the 40s.
Aluminum blocks see a little bit lower pressures but they pump more volume because of tolerances.
John Snyder
John Snyder
thanks for all your help much appreciated
John Snyder
John Snyder
Learned a few things I never knew today as well
Thebesta94
Dallas, TX
sensor might just be bad. I have had to replace 2 of them since I bought mine. They are a ***** to get too (back side of engine block wedged by the firewall) with my big hands but other than that not too difficult. Can get a all parts and custom socket for like $30 in total.
I only say this as my guage was tweaking out for about 2 weeks before it just read 0 pressure all the time. Brought it immediatly to the shop and it was holding pressure just fine... sensors just seem to go to shit pretty often
tjoyce81
The most likely cause of a low oil pressure issue in a 5.3 is a blocked oil pressure unit screen or an oil pump o-ring failure. HOWEVER - there is an often overlooked and very common issue that puts many of these engines in the junkyard FOR NO REASON. It is a weak or failing oil pressure relief valve inside of the oil pan. If ALL of the above does not fix the oil pressure issue - it IS the relief valve inside of the oil pan. The spring wears out in these valves, which causes oil to simply dump into the pan - and not feed the upper part of the lifter feed circuit. The oil pressure sending unit is located in this circuit - which is the reason you get a low oil pressure indication - when in fact oil pressure is good. The fix is to either replace this valve, or to simply install a plug so the oil does not dump into the pan.... When you block this off - oil pressure will be better than before....
Also, the tell tale sign of a failing oil pressure relief valve spring is a constantly fluctuating oil pressure indication, and pressure falling to zero after a few minutes - or low enough to set a "stop engine low oil pressure" message. If all of the above does not work, drop the oil pan and replace this valve or just block it off...
daves07 tahoe
My 2007 5.3l Tahoe w/225k has been suffering from fluctuating oil pressure, I replaced the screen and sending unit, no change. The pressure is very low (10psi or less) on startup, it climbs when engine RPMs are above about 1,000, but then quickly drops back at idle, I wonder if this could be the pressure relief valve, in the oil pan, you mention above. I did not know that existed. Could it be that sludge is causing the valve to stick? I am considering dumping a quart of ATF into the motor, running it at idle for 15-20 minutes, then changing oil to see if it removes sludge and frees the valve. A whole lot easier than dropping the pan. Thoughts?
wjburken
Eastern Iowa
I would suspect a bad o-ring on your oil pick up tube before a bad pressure relief valve. Either is possible, but based on the number of folks posting issues with oil pressure like yours, the majority solve it with a new o-ring on the tube.
