I have over 112k miles now
Rebate where?I just did mine with AC Delco Professional Iridium plugs. There is also a rebate on them right now
Its from GM, but if you go look up the plugs on RockAuto there will be a link to the rebate info. (https://www.rockauto.com/lang/en/promoCat.html#acdelcoPlugs)Rebate where?
I used the AC Delco wires as well.Denso wires or GM?
Wire preference?Delco, delco, or even better yet, Delco!
Wire preference?
Any benefit to running Taylor 10mm wires?
Where did you find Taylor’s? Now I’m interested+1 more vote for stock AC Delco plugs. I'd also recommend stock AC Delco wires but if any aftermarket, I'd +1 vote for Taylor. I've had problems with MSD and Accel and I know I've read of others having some issues. I used to find Taylors for cheaper than AC Delco and they're available in cooler colors, if you're into that sort of thing.
Called Taylor,I've only used the ones for the Gen3 and Gen4, but I get 'em from Amazon, Summit Racing, Jegs, eBay...
Here's a page from Taylor's application guide:
https://www.taylorvertex.com/spark-plugs/gm-ls-wires/
Called Taylor,
The only thing he said that bothers me was,
The heat shield around the plug will not fit over their plug boot.
