Odd sensation on acceleration from full stop
mountie
( My 2 cents)...... My great / old '88 C2500 was great... I put it on a lift.... I was astonished how easy it was to find loose steering / suspension issues. ( I rebuilt everything )
Put it up in the air. You can easily find problems, by checking the movement, due to everything hanging 'loose' , and other mounts / bushings, etc, can be easily checked.
SRQYukon
Sarasota, FL
I'm with Mountie. The best way to find anything related to suspension noise is up on a lift. With the ignition unlocked (so the wheels will move) have someone grab a front tire and move it back and forth while you look underneath. That will show worn tie-rod ends, idler or pitman arms. While its in the air you can inspect struts, universals, half-shafts, etc. If all looks good, then its probably internal.
J
jyi786
Update: took it into the shop. Had the most experienced tech take a look.
The front differential bushings are perfectly fine. What is shot?
The motor mounts.
Funny thing is that I did the motor mount test in my driveway, and didn't think I saw much engine movement. But when he did it? It looked like the engine moved way more than I thought. I don't know why I didn't see it. He also explained that's why I feel the thump/lurch when accelerating, and why I'm hearing the clanking noise randomly.
I've set an appointment to get the pinion seal and both motor mounts changed Tuesday.
PG01
Up here to the right
Yea..... You are right.......
Up on a lift will allow you to actually see if one or both are bad..... ( plus you can wipe off stuff to keep the bottom pretty )
If it ain’t leakin oil it ain’t a GM.... wait.... i mean harley..... meh....whatever :)
The motor mounts.
keep an eye on that pinion seal after it is done, if it starts leaking again within a month or two there could be other internal problems, just saying keep a heads up it's cheaper to get it fixed sooner rather than later.
HiHoeSilver
Away!
Chicago
The motor mounts.
Gonna use the solid Hummer ones for replacements?
J
jyi786
Roger that. It's exactly why I'm doing this right now, so that it doesn't turn into a super expensive mistake later.
Precisely. The Hummer H3 ones. Got them ordered on Amazon and shipped for tomorrow delivery.
J
jyi786
Update: this story has a happy ending, folks. It was indeed the motor mounts; they were pretty much destroyed. I had the shop replace both mounts and fix the leaking pinion seal. Here are pics of the old ones right before the shop tossed them.
20190903_163220.jpg 20190903_163208.jpg 20190903_163152.jpg 20190903_163150.jpg
The thump is completely resolved, and there is no clanking when going over bumps any longer. :):)
Many thanks to all you guys for helping me through this, especially @Doubeleive! Major props to you sir!
View attachment 229908 View attachment 229909 View attachment 229910 View attachment 229911
Next time, when you test some motor mounts, you F-IN' TEST THEM! Get on that throttle! :bleh:
GMT800 2005 Tahoe Z71
Navy Supporting Member
I would check the control arm mounts real close. The ball joints of course but maybe a lose or worn out mount where they attach to the frame area. The turn left and over a bump noise contributes to my concerns. Maybe even look to be sure there is no problem at the rack mounts.
Sorry, updated thread while I was typing this in. Congrats on the fix.
By the way I also agree that when checking motor mounts for problems, I have a friend hold ******* the brakes and "goose" the throttle pretty hard to see how much the engine will lift on each side.
