P0171 code and stalles at stop
zell66
Recently replaced fuel pump and a section of fuel line. (work complete 2 months ago and put on 2000 miles) Yesterday check engine light came on and it gave me the code above and stalled every time I came to a complete stop.This is a 5.3 l non flex motor.
Any ideas or direction I can go to fix this vehicle. Thank s!!
HiHoeSilver
Away!
Chicago
Bank 1 lean code.
Check for vacuum leaks.
Check fuel pressure at the rail.
Do you have a scanner that you can see/ graph live or freeze frame data?
Z
zell66
Well he is a conundrum....on a hunch filled tank and within 2 to 3 start and stop of engine, check engine light goes off and truck does not die at a stop. Could it be the fuel is sloshing around and fuel pump lost prime????
HiHoeSilver
Away!
Chicago
How much gas did it take? Could have been bad gas or high ethanol content.
Did you replace the pump itself or the entire assembly?
Z
zell66
A mechanic buddy of mine suggested it was the throttle body?
Nyc2011Denali
