My wife is the same. The vanity LEDs are great during the day, but at night they’re blinding. I haven’t swapped them back either.
I swapped my interior lights to LEDs years ago but never did the vanity mirror at all. Mainly because we never use it so it's an out of sight out of mind kind of deal for us. But now that I know it's way too bright at night I won't ever change them I guess LOL We've had our Suburban for over 9 years and that vanity mirror has been used MAYBE twice during that time for us LOL
BoxChevy216
Cleveland/Detroit
St. Louis
@Doubeleive what is the second pic of?
Btw, when playing around with the Tech2 the other day, I noticed that you can inflate or deflate the suspension. Mine was sitting at 17psi and I started to add air just to test it and realized that it wasn't shutting off. I manually stopped it and it was at 24psi. I then released it back down to 17psi.
I hope I didn't damage anything inflating it that high.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
the 2nd pic is just a little oem skid plate for the transfer case, it doesn't feel like much strength wise but it looks like the way it has grooves in it if I hit something it would deflect it instead of cracking the transfer case. air pressure wise it seemed to settle in around 18 psi after a couple key cranks then I jumped in and went around the block and it stayed around 19-22 psi, it varies a little depending on the angle of the rear end like when you turn a corner the psi will go up a hair and then back down as you straighten out. I see it has the shock dampner % command data in there also I may play with a little tomorrow driving around and see what it shows just out of curiosity.
HiHoeSilver
Away!
Chicago
All well and good for you Wes, but when most people turn, all 4 wheels stay on the ground!
lol, the air pressure will change as the rear end tilts even a little or if you jump on the bumper or rock the truck back & forth. that's why you have to do the ALC trimset with it sitting on level ground and no weight on it.
BG1988
get the GMC hybrid factory OEM LED way way brighter the those
Bright enough to light up the whole car behind you with SUPER BRIGHT RED light
honestly you waste your money on those..
the back up lights are Super bright
it's factory modified with heat shield shim ) the regular tend to melt
also the brightness you see there is just the running lights the brightness with the brake light is even brighter..
the back up camera is usable at night
note to self
replace DL3 door lights with white Transylvania Zevos LEDs
note to self
View attachment 229124 View attachment 229125 View attachment 229126
If they’re LED they do NOT get hot thus no need for heat shields. LMFAO again.
BG1988
the back up and signal are not as you can see the Reverse bulb is burnt to crisp (the base) so yes the heat shield is necessary..
Where'd you get the screws for it? Did they self-tap or were the holes already threaded on yours?
I bought the skid plate and bolts it was a different part number than just the skid plate, it came with 3 bolts I had a spare 4th bolt in my toolbox from my nbs and yes they self taped just had to push them a little to catch initially
I wondered about that, what was the PN# for the one with the bolts? Those things are $6-10 each online, GM is mighty proud of them!
Well put LED bulbs if for backup lights duh. JDM Astar’s are bright as hell and zero heat. Those incandescent bulbs are ancient technology. BTW how much time does a Prius I mean Hybrid spend in reverse in order to burn the bases and why would you recommend a tail light that burns up like that? Turn signals aren’t even led either? What does that leave - the park lights are the only led part of that thing? I’m pretty sure we will all pass on those lights lmao.;)
PG01
Up here to the right
23282726 I paid 54.94 last week which was about the cheapest from gmpartsdirect on eBay now they raised the price to $56.04
Yes i only used 2-3 bolts that i ‘found’ on, i mean under, another truck. No way i was paying that much for a bolt. :)
D Rollins
