Amateur Scanner / Diagnostic Tool
YukonCrazy
Raleigh, NC
As my 2008 Yukon ages, problems seem to come up more frequently and I would like to diagnose easier.
Is there a good tool that isn’t “professional dollars” that will help to diagnose issues beyond reading a code from a CEL?
For example, car is running a little rough but no CEL. Is that plugs or coil pack or dirty MAF? It would be nice to plug my laptop under the dash and read some useful data that would help in problem determination.
Big Mama
Virginia
Lots of guys here have the Tech2 which is what the dealer used for your rig. I’ve seen them around $300. Harbor Freight has a good lineup of readers for different levels of diagnostics the most expensive is $179 the ZR13. I went with this bc I have makes other than GM. Amazon has basic readers around $20. They can read the code and give you possible culprits. If you’re getting a reader get one that’s above your current comfort zone you’ll learn to use it pretty quickly.
Get a Tech-2. You can run graphs, save snapshots, see data saved from when codes were thrown, run every kind of test necessary to check things out and see everything GM intended for us to see with one AND you can program with it if you have to replace a module or want to add something not previously installed.
They pay for themselves in short order because they allow accurate diagnostics and trouble shooting.
the vxdiag (usb) $120 and a old laptop might save you a few bucks and should do most of the tech2 functions (tech2win)
Big Mama
Virginia
Most guys get them from EBay. Make sure the seller has good ratings and has sold more than a few. James can tell you the current version but I think it’s 33.004 or 044. I didn’t go with it bc it’s only for GM vehicles. Wes’s idea is a good one too
Big Mama
Virginia
Tech2 OBD2 is just the abbreviation for on board diagnostics 2nd generation
St. Louis
HiHoeSilver
Away!
Chicago
Is that a good price, $239+$59 shipping?
I see they also have one that comes with a case for $285+$85 shipping, but the case doesn't look like anything special and could probably get one cheap at Harbor Freight (heck, I probably have a dual pistol case in my basement somewhere that'll work).
Yeah, it's a pretty good price. Agreed on the case. The other good bet is a US seller on Ebay usually around the $315 range.
I like the factory case, it was made for it and all the accessories. There's always something better though, thankfully, I don't have to find out! hehehe
I paid $331 delivered with the case 2 years ago. Just the Tech-2 and all the stuff these days are about $350 so the flash sale is/was good.
drakon543
just feel like chiming in
cheap scanner for basic only scanning
actron pocket scanner
its very small and takes a beating ive had one for years
decent scanner with advanced features
innova brand scanner
read the descriptions on the model before you buy one. they have several different version and obviously price goes up the more features you want
good scanner and the go to here
tech2
i dont really think i need to add a description here.
Dannygtrr
Anyone here have a review on the bluedriver?
Sent from my banana phone.
There's 4700 reviews on Amazon. Simpler BT OBDII modules work well with Torque Pro phone app. Some guys even project that data onto aftermarket nav units.
These trucks were made for the Tech-2 and shop manual however.
CKendrick
