1badc4
- Joined
- Jun 17, 2019
- Posts
- 282
- Reaction score
- 216
Well after swapping in motor from my Z71 Suburban that was rusted out into my newly purchased Tahoe I got it registered and on Friday got it's first shakedown run which was a success, drove to work today. truck feels very smooth and tight, very happy with it, in it pretty good, $500 for Tahoe with motor that had collapsed lifters, $530 in parts for Suburban motor eg: new gaskets, oil pump, timing chain. I ended up with a decent Tahoe with no rust for just over $1,000. Tahoe appeared to have a recently rebuilt transmission due to an obvious new converter, I am also going to hang onto the transmission from my Z71 Suburban that I swapped motor out of into this which was a GM Goodwrench rebuild as a spare. I am now parting out the Z71 Suburban to recover my cost of swap. only issues now with Tahoe is the air is not blowing cold. when I bought it I was able to run it with bad motor and I charged the air a it blew very cold, but during swap it lost the charge, I ordered freon and leak detector dye. on my Suburban it stopped holding the charge and was rear air line which I did block off plates and it worked fine. hoping same here as I can just use those same block off plates. either way the burb air was cold so I have all and any parts needed, the only other thing is I hate the wheels.
