The Case for the Tech-2
trailblazer
It says you have 24 months to program all the modules in the vehicle one time? That’s it?
Yes. I like it versus the old way (they changed it in the last year). It used to be where you can get a $55 72-hour subscription pass to get unlimited vehicle calibrations access for any GM vehicle. Now you pay $40 per VIN to get 24-months access. I like it better than the old way as I can work at my own pace. For example I am installing the OEM seat heaters in the next week or so. I can program the RCDLM as needed later on.
For those that don’t want to take the “risk” of buying a Chinese Tech II clone, I saw in Amazon they have a J2534 pass thru device for like $150-200. At least you can easily send it back to amazon if it doesn’t work. With this device you can get a temporary subscription to Tech2Win for $55/3-days.
The only problem I see is if you want to change something more than once.
trailblazer
I have yet to experiment with that. The way I read it, you can only make the total amount of changes that the truck was originally configured for. In other words, if the VIN has 38 module sections then you can do a total of 38 firmware/calibration updates (regardless of if you update a single module 38 times). Someone can call ACDelco TDS Support and clarify that.
For those new to this calibration/firmware crap, Individual vehicle modules (i.e. BCM, RCDLM, TCM, etc) have various subsections that can be updated. The java based ACDelco software will tell you if you already have the latest version. Some modules have “either or” options for updates to customize a drivers request such as auto-door locks. There is a calibration update that forces the vehicle to NOT automatically lock the doors (and even eliminates the user controlled option from the DIC menu). But you can install a calibration that does the opposite.
09 L9H
not a boomer
Upstate SC
So I signed up for the ACDelco TDS website a month or so ago because I saw the Tech2 emulator, but I'm still confused. What do I need besides a laptop and an OBDII connector?
Also, anybody have a tutorial on how to get into the BCM and disable hyperflash on our trucks? I bought LED bulbs like 6 months ago but haven't put them in my turn signals yet cause I still have hyperflash.
trailblazer
You need ANY functioning J2534 pass-thru device. Those with a Tech II have have the option to use it as a pass-thru device or as a standalone (connect to car, download vehicle data, connect Tech II to PC and connect to TIS2000 and download calibrations, disconnect and then re-attach Tech II to vehicle and flash the new calibrations).
Other way is to buy the Drew Technologies J2534 device or get a Chinese clone of that. Go on Amazon and search for VXDIAG VCX Nano. $120. Remember if you’re not using genuine equipment then you are risking bricking your modules. I’ve never had an issue. Just makes sure you ALWAYS hook up your car battery to a good charger to maintain voltage. Sometimes the flashing takes half hour and you can brick your modules if the voltage drops too low. I hook mine up to my Schumacher 200Amp/40Amp charger-starter box.
09 L9H
not a boomer
Upstate SC
Much appreciated, thanks.
grouch
I'll stick with my old stand by tools. Some I've had for decades. A huge vacuum gauge, volt/ohm meter and a 24 inch wooden dowel rod. I've got a couple of OBD II readers and they are handy but I tend to swap vehicles a lot and dedicated tools just collect dust. Over the years, I've had somewhere around 250-300 cars and trucks that I plated. This doesn't include parts vehicles.
live2pull
Phoenix, Az
Ummmm. The seller has 0% positive feedback. I would buy from a seller with a lot of positive feedback and plenty happy customers who have bought Tech 2’s from them specifically.
That is a good point, I honestly never thought about the seller rating.
And that fella lists Alabama and China and that it ships worldwide. Probably coming from China, nothing wrong with that, just pointing it out. I'd select another vendor with multiple sales and good reviews. There are lots of vendors (probably a same few) selling them for $335 delivered.
There are a ton of "originals" for sale too! I've seen an original Vetronix from 2010 and it looks no different from mine made in 2017, so buyer beware.
homesick
The Best Me I Can Be
Navy Air Force
I'd have to be pretty desperate to buy from a guy with zero transactions under his belt.
Also, a high score as a buyer doesn't help you much either. Go through a seller's feedback. Make sure a good chunk of his (high) score is from sales. Then, as someone said, look for feedback from him selling the specific item you want to buy.
joe
live2pull
Phoenix, Az
joe
Just trying to find a reputable source for one of these. Im not against a china knock off, $2500 is a hard pill to swallow for a genuine. It seems to be a tall order to find a reputable seller with multiple transactions for one of the in the <$400 range.
There's little if any difference between them anymore, save for the much older ones, before Vetronix made them. I would not worry about a Chinese one, that's who made them for decades! They just kept on making them since they were tooled up already.
Try AliExpress and ChinaCarDiags.
Big Mama
Virginia
James, just wondering under manufacturer it says “does not apply “ does that mean anything?
MoundMedic7
