2006 Yukon XL hydro boost pump..
Woodblocker55
I have a steering gear box leaking out the seal by the pitmen arm .. I put new seals in and started leaking again . How can I tell if I have the right power steering pump . As looks like it might have been changed by previous owner. If I look in Rock Auto it's ac Delco silver pump I have a Black pump .
I'm wondering if owner before me changed it with none hydro boost pump. Any info be great.
Sent from my LGL84VL using Tapatalk
Joe yukon
Just so you aren't chasing your tail: power steering pump wouldn't cause your steering box to leak
Then whats difference in power steering pump between a Yukon with hydroboost and vacuum brake boost ? In Rock Auto there $50 more with hydro boost.
Sent from my LG-H900 using Tapatalk
SnowDrifter
Sasquatch Country
Not really sure it's a "then" question
Could you provide the part numbers you're looking at?
Woodblocker55
Woodblocker55
Here's the right one I have the 4x4 7200 lb and rim P27 but without BPH
Woodblocker55
Woodblocker55
Here's the steering, hydroboost pump. It's black is others with hydroboost brakes have a black pump ? 2006 Yukon XL ?
Drewphil
